Stalling problem need help
Old January 5th, 2007, 02:02 AM   #1
Booger is on a distinguished road
Hey guys i got my motor to run but now i got more issues. first to let yall know i got a 302 with b303 cam, holly carb,points distrib, and mallory fuel pressure reg, and 513 gears.Also this motor is in my truck but im asking yall cause you all have more knowladge than the 4x4 guys.
heres the problem i start it it fires up strong but dies in 5secs start it back up warm it up a bit and it idles ok sometimes stalls, but i drop it in gear and dies. the exhaust smell a bit rich.
heres what im thinking.
pressure regulator? how do i adjust?
carb issue?
vacume issue?
Timming?
i know theres alot of reasons it could happen but just looking for insight.
Old January 5th, 2007, 02:09 AM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
i think a vacume line myself..
513 gears? do you start out in forth geesh.lol
Old January 5th, 2007, 03:08 PM   #3
yeah thats what i was gunna start with then try the carb, i got thiat stupid vacume thing were its for 1 vac in and like 30 out junction thing, but i only need 2 lines so it might be leaking around the 20 bolts i got jammed in the vac lines. lol
Old January 7th, 2007, 01:53 AM   #4
'79 393 hatch
bigdog89129 is on a distinguished road
check the fuel pump (if its mechanical) by unhooking the fuel line at the carb put your thumb over the fuel line & crank the engine if there is little or no pressure, the the fuel pump is shot. be sure to pull out the coil to distributor wire to prevent ignition.
Threads Similar to: Stalling problem need help
Stalling Around 95StangMX 94-95 2 October 19th, 2007 12:39 PM
The Infamous Stalling Problem mikethetigerrr V6 Mustangs 12 March 18th, 2007 03:56 PM
'01 Stalling problem LanceD V6 Mustangs 11 March 5th, 2007 01:15 AM
Stalling problem need help Booger 5.0 Mustangs 2 January 7th, 2007 09:07 PM
Stalling Problem Mustang8719 5.0 Mustangs 12 July 27th, 2006 11:42 PM
