1985 Mustang GT
what went wrong?
my old block has YYY under the intake, and my new one i just bought (new but old) has XXX in the same place.....
is this telling me i cant use my rollers and etc...????? |
1985 Mustang GT
well what i mean is from my old block, down the main valley was this piece held down by 2 screws that had 4 arms extending out from each side holding the rollers in place....
my new block i picked up has no spot for me to screw this down...what do i have to do in order to get my rollers to work with this block? looks like these, but 2 bolts hold it down Edelbrock 97386 - Edelbrock O.E. Style Hydraulic Roller Lifters - JEGS Last edited by viperlocc; February 4th, 2009 at 09:24 PM. |
1990 5.0 LX Notch
I believe that is a non roller block. If you are going to use it you will need to do the conversion.
1990 5.0 LX Notch
89 Mustang
What year block do you have does it have the boss where the holes go? if so just drill and tap them for the bolts.
Just another turbo Mustang..No dyno numbers just good ets and MPH. And yes it is fast for a street car. few parts for sale https://docs.google.com/document/d/1...l=en_US&pli=1# |
i am pretty sure XXX and YYY blocks are both roller blocks. could be wrong
just take it to a machine shop 30 bucks later its drilled and tapped end of story
1985 Mustang GT
xxx is a roller block.. but it's not. Has provisions and slightly taller lifter extrusions. Just have to drill/tap the 4 for the lifter spider as said above.
ditch the HO cam.. atleast put an alphabet cam in there as they are tossed out left and right super cheap.
weeee foooord!
1985 Mustang GT
started to drill and noticed that the 2 spots where i need to drill are right above where the cam is stableized or whatever to the block.
dont have the money to replace all the lifters, what options do i have? do people sell used lifters? or do i re-buy the spider/retainers that have 3 screws in different location than the one i have (i believe its the ford racing) Last edited by viperlocc; February 6th, 2009 at 08:36 PM. |
either be very careful or knock the cam bearing out and then reinstall the bearing after youve drilled and tapped, hence the pay the machine shop to just do it
1985 Mustang GT
so im gonna have to remove the pistons/rods/crank and have a shop remove the cam bearings, drill 2 holes, and re-install everything with new shit, again? im about to sell the car as a roller block and be done with it.
1985 Mustang GT
is this all ill need? Ford Racing M-6500-S58 - Ford Racing Lifters - JEGS
only 500 bucks, it costs nothing for you to take the crank/rods/pistons out, just number which one they came from and what direction they faced, take the bare block and some cash, have the work done, then put said crank/rods/pistons back into the right cylinders facing the right direction
my friend has a set of good used roller lifters and spider
let me know if you need it
weeee foooord!
#16 | |
1985 Mustang GT
you can reuse thebearings
thats no big deal
the bearings are like the pistons, they gotta go back where they came from
Threads Similar to: what went wrong?
| Am I doing it wrong? | DickH | 99-04 | 22 | December 15th, 2008 01:58 AM |
| what is wrong with this ad? | vfast | The Clubhouse | 8 | June 5th, 2008 07:36 PM |
| Something must be wrong with me | WAR-PARTY | The Clubhouse | 15 | May 27th, 2008 01:57 PM |
| What's wrong with AM? | RAGEman | The Clubhouse | 9 | April 16th, 2008 03:51 AM |
| What's Wrong | HMUSN | The Clubhouse | 34 | December 14th, 2007 01:29 PM |
