Weird problem to have
Old February 4th, 2009, 09:21 PM   #1
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
I recently did a quick freshen up on my stock motor after I blew a ring threw the piston out the valve. And it's held up great I replaced every seal etc except.... I used the stock oil pan and on the side the oil level sending unit is starting to leak like shit and it's really pissing me of. I'm about to order a new motor from woody with my tax money but I one it'll be like 8 weeks and I still like drive my car and keep spraying a 200 on it in the mean time . Is there an easy solution to this shit or am I screwed?
Old February 4th, 2009, 09:48 PM   #2
91 gt 5.0 is on a distinguished road
easy solution like...drive it and fill up the oil and check the gas?
Old February 4th, 2009, 09:48 PM   #3
89LX347's Avatar
89LX347 will become famous soon enough
is the threads stripped?can you put some silicone around it?
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old February 4th, 2009, 09:58 PM   #4
Atomized
gotn20's Avatar
Is it threaded? It's leaking to bad for my garage and I can't stand oil all over the underside of my car. I was hoping there was a way I could drain the oil and replace the seal or whole unit or something. I can't figure out if it comes out or not
Old February 4th, 2009, 10:09 PM   #5
1987 ford mustang gt
well see when shes done
There is a little bung welded to the inside of the oil pan.. About the only thing you could do for now is silicone..
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old February 4th, 2009, 10:34 PM   #6
Atomized
gotn20's Avatar
Shit that's what I thought. I just won't drive it. I took the wire out and it's a ball of silicone and it didn't help. Thanks though. That's a stupid ass design pull the motor to fix a sensor leak
Old February 5th, 2009, 01:12 AM   #7
jer5ak is on a distinguished road
JB weld it . Its cheap and easy to do.Clean with brake clean, apply and add new oil . Thats it.
Old February 5th, 2009, 10:45 AM   #8
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
jb weld ftw. Man 200 shot? Must ride out decently.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old February 5th, 2009, 11:28 AM   #9
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
drain the oil let it sit for awhile spay it down with brake clean and jb weld or cold weld its in a round tube at the auto parts store the best stuff is called sure seal in a yellow tube. It's like hard play doe rub it around until it gets warm and place on the leaking area. I have had it on a oil pan on a snow plow truck for 3 years not one leak.
Threads Similar to: Weird problem to have
Weird Problem dothedew1654 5.0 Mustangs 3 July 25th, 2008 05:09 AM
Weird LED problem? SUHLeen 2005 - 2010 0 June 4th, 2008 10:19 AM
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 12:03 PM
weird problem Reggedon 99-04 6 January 9th, 2008 09:40 PM
Weird Idle problem geolebon 99-04 17 February 17th, 2007 09:10 PM
