Ring Gear?!?!?!
Old February 5th, 2009, 05:03 PM   #1
1990 5.0 LX Notch
flamed 98 gt is on a distinguished road
Ring Gear?!?!?!
Just had a bolt break off while changing the diff. There are still 9 bolts that will hold it on. Ok to run or not? I talked to a big time drag racer and he said that it would be fine. I guess I am looking for a second on it.
Old February 5th, 2009, 05:48 PM   #2
89LX347's Avatar
89LX347 will become famous soon enough
big time drag racer huh? i guess that means he has had 9 bolts in instead of 10?
is the threads of the bolt still in there? more than likely your gonna wind up trying it like it is anyway
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old February 5th, 2009, 06:17 PM   #3
baine21225's Avatar
get it out and fix it before it (potentially) causes other problems
"Whip out your dick you'll either get it sucked or get smacked..."
Old February 5th, 2009, 07:24 PM   #4
1990 5.0 LX Notch
Well I tried to use an easy out and it broke. I just went and bought some 3.73's and drop down from the 4.10's maybe it will help me out some at the track.
Old February 5th, 2009, 07:25 PM   #5
1992 Lx
11.39@119.24
when i switched from 3.73s to 4.10s it did zero to my trap speed, i did run 2/10s faster though but that was just cuz i cut a .10 second better 60' time
Old February 5th, 2009, 07:28 PM   #6
1990 5.0 LX Notch
Well in the 1/8th I am going into 4th right before the finish. I figure if I can stay in 3rd it will save me some time.
Old February 5th, 2009, 07:29 PM   #7
1992 Lx
11.39@119.24
WTF on a t5?
Old February 5th, 2009, 07:29 PM   #8
1992 Lx
11.39@119.24
how fuckin fast are you trappin?
Old February 5th, 2009, 08:04 PM   #9
1990 5.0 LX Notch
Yep on a t-5. I spin all of first most if second and part of third and it runs 7.7x @ 94.
Old February 5th, 2009, 08:08 PM   #10
1992 Lx
11.39@119.24
lololol ok your cars a lil faster than i thought so it makes sense now
Old February 5th, 2009, 08:13 PM   #11
91cobra5.0's Avatar
94 GT
you should really find out what made the bolt vibrate out? bad shimming of the gear? or unbalaned driveshaft? make sure that when u put it back together that u use heavy duty locktite on the bolts going into the ring
94 GT - Deep Forest Green
Off road X, flowmaster single chambers, typhoon intake, hurst short throw, CAI, eibach sportlines, 315s, foxbody short block
Old February 5th, 2009, 08:29 PM   #12
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
a bolt holding the ring gear?
Old February 5th, 2009, 08:32 PM   #13
91cobra5.0's Avatar
94 GT
yea bolted to the carrier
Old February 5th, 2009, 08:35 PM   #14
1990 5.0 LX Notch
I am going to 33 spline axles and a spool. I seem to twist the stock ones in half..
Old February 5th, 2009, 08:35 PM   #15
M L Struck's Avatar
is the ez out still in the bolt?
Old February 5th, 2009, 08:39 PM   #16
1990 5.0 LX Notch
Yep. It broke off in it.
Old February 5th, 2009, 08:42 PM   #17
M L Struck's Avatar
how deep is the ez-out can you use center punch and hammer to move the ez out back and forth is it broke off flush?
Old February 5th, 2009, 09:29 PM   #18
1990 5.0 LX Notch
When I get some time going to try and remove it. Then sell the gears since I dont need them anymore.
Threads Similar to: Ring Gear?!?!?!
Re-use ring gear bolts? Jackson 5.0 Mustangs 1 May 24th, 2008 03:51 PM
Ring and Pinion Q? eLLuSioNiST 2005 - 2010 17 May 11th, 2008 09:53 PM
Ring and pinion gear question 06silvergt 2005 - 2010 2 September 13th, 2007 06:29 PM
For anyone who has done a ring gear install MySallyMI V6 Mustangs 8 May 27th, 2007 12:59 PM
O-Ring 5-0stank 5.0 Mustangs 10 February 6th, 2007 10:13 PM
