LinkBack (1) | Thread Tools |
#1
Serpentine Belt w/ A/C, P/S, and S/P Deleted
I have a 91 Mustang GT that i've deleted the p/s, a/c, and s/p on. Plans on installing a turbo set up but I'm trying to clear up the engine bay before I go any further. I'm trying to find out what size belt I need and how to route it in order to incorporate the water pump with the alternator still in it's stock location if at all possible. If any one has done this or know anybody who has please help me out
what turbo set up are you planning?....ponydown?
if its a hotside kit, you can move your altenator over to your ac bracket and have plenty of room for the turbo. |
in this build he kept his power steering, and moved the altenator and just used a junk 2.3 idler pulley.
take a look, i will be doing a turbo build on one of my projects and am going to do this same set up but im going to use a hotside kit.88 GT Auto Holset Build "Going for $1000 Total including the Car" w/Video & 1/4 |
I'm either going to piece one together using B&G pre-fabbed headers or just go with their stage1 setups but right now I'm pretty much just mocking up the car right now. I wanted to keep the alternator where it was because I already did the wire tuck in my engine bay and I'm tired of soldering
and heat shrinking . I guess a better question would be, "does anybody make a ribbed pulley?" I've already got my backup plans set with a March Alternator Bracket and either a Proform/Moroso Water Pump Electric Drive Kit but I really want to drive my car before I leave for another deployment.
1990 Mustang GT
13.64 @ 101 MPH
i beleive it is a 42.5 belt. cut the tab off the back of your tensioner and you will manually pull up on it then tighten the bolt and route the belt like this:
![]() rep points will be taken to the left
![]() 90 Ford Mustang 5.0 T5- BROKE 1.9 60' on street tires13.64 @ 101 MPH 89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8 |
I'ma give it a try tomorrow after work as long as the parts stores around here have the belt I need.
here's a pic of how I did mine.. this works great providing you have an electric fan
Heres mine
PeteAndersonRacing.com |
1990 mustang gt
eventually
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
3g and a tuarus fan
hey 93mustank, is that gatorback your using a 42.5" belt. you think u could save me the hassle of dealing with the customer service at the parts store and hook me up with a part number
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/108963-serpentine-belt-w-c-p-s-s-p-deleted.html
| 5.0 Pulley setup for minimal accessories - DFWstangs Forums | This thread | Refback | February 9th, 2009 03:00 AM | |
Threads Similar to: Serpentine Belt w/ A/C, P/S, and S/P Deleted
| Serpentine Belt? | 93HatchsBFF | 99-04 | 0 | November 12th, 2008 10:07 PM |
| serpentine belt | emgjsdk1 | V6 Mustangs | 17 | March 18th, 2008 06:20 PM |
| serpentine belt | gripgb | 99-04 | 1 | February 6th, 2008 09:42 PM |
| serpentine belt | terribleonexx88 | 5.0 Mustangs | 2 | October 19th, 2006 11:15 PM |
