car took a crap!
LinkBack (1) Thread Tools
Old February 5th, 2009, 09:05 PM   1 links from elsewhere to this Post. Click to view. #1
mustangsoldier's Avatar
1993 Mustang
we'll find out when i come home from iraq.
mustangsoldier will become famous soon enough
car took a crap!
everything has been running fine on my car and just now i pull up to the house and my foot slips off the clutch and i stall out, i go to start it up and its like the battery is all of a sudden dead, you can hear it try to crank over and then you get the clicking sound... im thinking alternator but it just doesn't make sense b/c i haven't had a problem at all w/ it and i had just started it 10 minutes prior no issue.
shut up before i punch you in the throat
Old February 5th, 2009, 09:20 PM   #2
1992 Lx
11.39@119.24
jump the starter solenoid, maybe its bad
Old February 5th, 2009, 09:39 PM   #3
1993 Mustang
im going to take it to autozone tomorrow to get the alternator checked
Old February 5th, 2009, 09:55 PM   #4
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
charge the battery and clean your terminals
Old February 5th, 2009, 09:59 PM   #5
1993 Mustang
i hope its something small but just doesn't make sense
Old February 5th, 2009, 10:33 PM   #6
89LX347's Avatar
89LX347 will become famous soon enough
take your battery up there too
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old February 5th, 2009, 10:38 PM   #7
chozenfew805 is on a distinguished road
Make sure you clean up all your terminals and other contacts also after you test your alt & batt
Old February 5th, 2009, 10:45 PM   #8
1993 Mustang
lol thank God this is a 4 day weekend
Old February 6th, 2009, 12:57 AM   #9
sean1017's Avatar
1993 gt
sean1017 is on a distinguished road
Send a message via AIM to sean1017
this same thing happened to me not to long ago on my notch. The starter solenoid went out and when id try and start it and it make a click noise. It was so rapid it almost sounded like a machine gun. Ended up jumping the solenoid and it fired right up. Hope you have better luck then i did! I ended up replacing the starter and wires before i figured it was the solenoid!
Old February 6th, 2009, 04:56 AM   #10
qwik48r's Avatar
alotta shit
no fat girls fast
qwik48r is a jewel in the roughqwik48r is a jewel in the roughqwik48r is a jewel in the rough
Send a message via AIM to qwik48r
alternator... it had enough charge in the battery to run... the when you shut it off, not enough to send 500amps to the start... pretty common.. they do that..
when was your last tune up?
mind your business what i drive... i'm on a fucking mustang forum.
qwik's build
Old February 6th, 2009, 07:55 AM   #11
1993 Mustang
i just got back from iraq 2 weeks ago so i havent yet... so are you saying i need to replace the alternator?
Old February 6th, 2009, 09:06 AM   #12
qwik48r's Avatar
alotta shit
no fat girls fast
take that bastard to advanced and have them test it
qwik's build
Old February 6th, 2009, 01:24 PM   #13
hopper is on a distinguished road
i had the same thing happen. mine was the negative cable on the end that bolts to the engine/chassis. a little corrosion with fuck it up
Old February 7th, 2009, 01:56 AM   #14
1993 Mustang
ok so an update... didn't get to really work on it today.. too may erands, i did get in it today and tried to crank it and it actually started, but i didn't give it any gas so it died, i go to start it again and it just sounded like the battery was dying..
Old February 7th, 2009, 12:10 PM   #15
1998 Cobra
13.24@105.66
battery prob trickle charged back up..
sounds like a bum alternator/wiring..
check for solid grounds and your charging wire. Take it up to advanced and have a battery load test done.. should stay about 9.75v during cranking, then batt is fine.
should charge 13.5v + and above 13 with load I.i. lights and heater fan on
weeee foooord!
Old February 7th, 2009, 05:00 PM   #16
1993 Mustang
ok, im going to start working on it this evening or tomorrow, i got hit bad w/ the flu so im feeling pretty shitty right now...
Old February 7th, 2009, 08:46 PM   #17
1993 Mustang
ok so good news, just got back from autozone and it is just the alternator so i picked up a duralast 75 amp alternator for 100 bucks, so not too bad. i get to spend tomorrow doing that.
Old February 8th, 2009, 12:00 AM   #18
1993 Mustang
i just went outside a couple minutes ago and my car started right up... WTF?!?! could it just be the alternator is starting to go out or what?
Old February 8th, 2009, 12:35 AM   #19
blue90lx's Avatar
90 lx hatch
12.83@105
blue90lx is on a distinguished road
Send a message via AIM to blue90lx
could be a loose connection somewhere man check everything first before you spend alot of money on parts could just be a simple fix.
to many parts and money to be so slow
Old February 8th, 2009, 12:36 AM   #20
1993 Mustang
i already bought the damn alternator lol, im going to get in there and check all my connections and if i find a loose connection im taking the damn thing back.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/108993-car-took-crap.html
car took a crap! This thread Pingback February 6th, 2009 09:39 AM
Threads Similar to: car took a crap!
Mustangs Are Crap Get A Real Car petespug The Clubhouse 1096 May 5th, 2008 03:56 AM
Car started running like crap! Euroeater95 94-95 3 April 11th, 2008 10:51 PM
Car Runs Like Crap 1bad5.0 94-95 9 January 15th, 2008 03:38 PM
Audi's are crap, get a real car.... FaStStAnG5-0 The Clubhouse 49 December 20th, 2006 06:05 AM
Car Is Acting Like Crap? jaystang98 96-98 14 September 21st, 2006 09:32 PM
