water pump question
Old February 6th, 2009, 10:31 AM   #1
hopper is on a distinguished road
water pump question
ok putting an 89 engine in my 84 5.0
question: i was told that i can not swap my water pump onto the 89, He said they turn in different dirctions. ???? i haven't looked yet to see, or is he full of shit.
Old February 6th, 2009, 11:08 AM   #2
91cobra5.0's Avatar
98 Cobra
any parts from 87 to 93 for the 5.0 will interchange
Old February 6th, 2009, 11:43 AM   #3
will the 84 pump go on the 89
Old February 6th, 2009, 11:53 AM   #4
1998 Cobra
13.24@105.66
just use the 89 pump? and stop being cheap and get a 15$ water pump?
weeee foooord!
Old February 6th, 2009, 12:14 PM   #5
badshoe is on a distinguished road
The 84 water pump will be a standard rotation and the 89 will be a reverse rotation. If your keeping the 84 V belt and pullies, you need to stay with a standard rotation pump and yes it will bolt to the 89 engine. I would buy a new pump however.
BadShoe Productions, How-To-DVD's specializing in Ford drivetrains www.BadShoeProductions.com
Old February 6th, 2009, 01:18 PM   #6
that was the problem, i had nothing on the 89 engine. so i was hoping on useing everything from the 84 including the water pump.
Old February 6th, 2009, 01:19 PM   #7
that was the problem, i had nothing on the 89 engine. so i was hoping on useing everything from the 84 including the water pump. the pump is brand new for the 84
Old February 6th, 2009, 02:40 PM   #8
86er's Avatar
for a cheap up grade look at the late 70's or early 80's 351w. They had a heavy duty cooling option, aluminum higher volume factory water pump.
and as stated above, using vbelts needs to be pre serpentine waterpump
Just a truck
Old February 6th, 2009, 03:06 PM   #9
this is odd. my 84 engine has a sepentine belt on her. what direction should the pump be turning in. this will really screw with my head
Old February 6th, 2009, 03:24 PM   #10
Is your water pump pulley grooved or smooth?
Old February 6th, 2009, 04:00 PM   #11
86er's Avatar
serpentine w/p were counterclock wise
Just a truck
Old February 9th, 2009, 08:33 AM   #12
yes this is counter clockwise, and the pully is smooth, this must be a later engine then i though. however looking at the fireing order it is not an HO,
any suggests
Old February 9th, 2009, 12:52 PM   #13
ryans88gt's Avatar
Someone may have just replaced the water pump with a newer style water pump.
Anyway, any 302-351w style water pump will work on any 265-351w block. You just have to know which way to spin them and what gaskets to get. Also, if you still have a mechanical fan, you want that to be spinning the correct direction as well.
Old February 9th, 2009, 01:14 PM   #14
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
who makes a 265?
Old February 9th, 2009, 04:37 PM   #15
now i am confused. so the 84 never came with a sepentine belt, and the pump turned clockwise. however i have a serp belt and a counter clockwise pump.
if he was just to change the pump, would he not have to change all the pully stystem aswell?
Threads Similar to: water pump question
Suggestions for an electric water pump or water pump motor. N. Dave 5.0 Mustangs 4 October 5th, 2008 08:49 PM
Fuel pump question. Stock GT pump to GT (supercar) pump. Nate's4.6 99-04 15 May 14th, 2008 02:25 PM
86 water pump question 78mach1 5.0 Mustangs 3 February 18th, 2008 06:59 PM
Electric Water pump question lugthug713 94-95 3 December 22nd, 2006 12:05 AM
water pump going? magnifistang 5.0 Mustangs 8 January 12th, 2006 09:49 PM
