pro comp heads
Old February 6th, 2009, 07:46 PM   #1
5mustang0 is on a distinguished road
pro comp heads
Whats your guys opinions on pro comp heads?
Old February 6th, 2009, 08:33 PM   #2
89LX347's Avatar
89LX347 will become famous soon enough
might wanna go ahead and use the search option on this one
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old February 6th, 2009, 11:03 PM   #3
JBIGBOOTSY's Avatar
1990 LX hatch
I have a set, 215cc, good power gain, went on fine, good castings. I did use good hardware and springs tho.
Old February 6th, 2009, 11:49 PM   #4
2002BLGT is on a distinguished road
Send a message via AIM to 2002BLGT Send a message via Yahoo to 2002BLGT
can you post more about your setup and what kind of times you are running with them ?
Old February 7th, 2009, 12:08 AM   #5
86er's Avatar
86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold
garbage
Just a truck
Old February 7th, 2009, 02:02 AM   #6
go to Web Page Re-director and search there are many many threads on how horrible the quality is on these heads and how people didn't gain nearly as much as they shoul dhave when compared to other heads of the same caliber.
Old February 7th, 2009, 06:58 AM   #7
JBIGBOOTSY's Avatar
1990 LX hatch
This is the only pick I have that the casting arn't that bad. Really they arnt.
All the bolts lined up suprise free install.
215cc runners, 2.02/1.64" stud mount,64cc chambers. 1.45"125#seat pressure, comp cams Stainless 1.6. trickflow pushrods.
I had a stock shortblock, I fly cut my pistons with a Dremmel. PP Typhoon intake, 65mm tb, 30# inj, 76mm maf.
Im not gonna be posting times, just the head swap gained me 7mph, over ported p heads, with 10:1. my compression droped with the procomp to just over 8.5:1
Old February 7th, 2009, 12:28 PM   #8
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
You have a 50/50 shot on getting hunk-a junk castings with the Pro-Comps
Some people use them without issues, some people have nothing but headaches.
Get what you pay for.
And...... is it just me or are the exhaust and intake actually touching in
the above picture ? ...... looks like they are to me ...... not good.
Twisted Wedge
RHS - CompCams ---- the old Pro-Topline heads for Austrl.
AFR
Dart
are the only heads I would mess with.
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old February 7th, 2009, 12:32 PM   #9
86er's Avatar
im loving my edlebrock Vic Jr's
Just a truck
Old February 7th, 2009, 12:33 PM   #10
86er's Avatar
Twisted Wedge
AFR
Dart
you look close enough, you can see its close, but they dont touch
Just a truck
Old February 7th, 2009, 05:40 PM   #11
JBIGBOOTSY's Avatar
1990 LX hatch
I'm just courious, but how many people leaving advise have used the heads?
The heads flow in the 260s @.550, and thats with the valve guide extending into the port .25". Not the best in flow numbers, but good for a 700 dollar set of heads, IMO.
If you ask me, I say they only suffer in the flow area. They have been reliable, under race conditions for me?
Old February 7th, 2009, 06:10 PM   #12
i just need a better set of heads the stock set of heads on my 351 r terable
Old February 7th, 2009, 06:17 PM   #13
86er's Avatar
ive worked on two cars with them, valves didnt seal, the holes for the studs werent straight caused the rockers to sit katywonker, the spring perches were three different heights
hows that?
Just a truck
Old February 7th, 2009, 06:39 PM   #14
JBIGBOOTSY's Avatar
1990 LX hatch
hows that?
What size were the rocker studs? What was the valve length?
Old February 7th, 2009, 06:52 PM   #15
86er's Avatar
couldnt tell you the valve length it had 3/8 studs.
the holes for the studs had almost a 2* rake to them left to right.
Just a truck
Old February 7th, 2009, 06:55 PM   #16
JBIGBOOTSY's Avatar
1990 LX hatch
How did you find that out?
Old February 7th, 2009, 06:59 PM   #17
86er's Avatar
well when you put the stud in, instead of sitting vertical with the others, all 8 studs looked like the leaning tower of pisa, so off to the machine shop we went and low and behold they were all off
Just a truck
Old February 7th, 2009, 06:59 PM   #18
86er's Avatar
before you question the machine shop, it was Huntsville Engine, look them up if you doubt their work too
Just a truck
Old February 7th, 2009, 07:04 PM   #19
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
to many good heads on the market to waist time and money on something with so many bad reviews "50/50" chance dosn't sound to good to me. I have no expereance with these heads but I have heard a ton of back and forth talk about them, so stick with a trick flow, edlebrock, afr, canfields.
Old February 7th, 2009, 07:28 PM   #20
so ur saying that i shouldn't even bother with procomp?
Threads Similar to: pro comp heads
Pro Comp aluminum heads? Bigfatts 5.0 Mustangs 6 May 12th, 2008 11:52 PM
Stiff shifting with Hurst Pro Comp shifter jacutis V6 Mustangs 10 January 9th, 2008 11:12 AM
are pro comp heads junk Iownastang 5.0 Mustangs 24 July 20th, 2007 06:42 PM
Pro Comp roller rockers Bossman351 Parts 5 August 31st, 2005 11:02 AM
