gt40 p heads
got a set of heads for my buddy's car. they are the gt40 p heads off the exploders...i heard rumor that regular mustang headers will not work with these heads, that you had to buy some special ford motorsports headers....ive talked to some friends of mine and they have never heard of this...whats up
It's true
1982 GT (t-top) 351w(.060),10:3, ported & polished iron heads, 1.94/1.60 valves, BBK shorties & flowmasters, 274XE cam, stealth intake, mallory dizzy, stealth intake, 750dp, Edge 3700 stall converter, C-4, 4:10's Best E.T 12.85@102mph |
It may or may not be true. The problem lies in the repositioned spark plugs. If your current headers and wire boots clear the headers, fine. If not, you'll keep melting the boot / wire.
Some headers will work. The spark plug hole is moved down and rotated out which puts the electrode closer to the center of the combustion chamber. Standard unequal length shorty headers won't work because of the GT40P spark plug location. MAC offers a coated GT40P specific shorty and Ford Racing offers a set of stainless shorties that work. Stock Mustang headers work also. Most equal length shorties will not work. BBK equal length shorty headers have been known to fit. MAC, Hedman and BBK full length 1 5/8" headers fit. Some full length headers require minor clearancing on some primary tubes but is not a big issue. Spark plug wires with 90 degree boots are very helpful.
thanks for the help fellas
Yeah, I didn't want to mention that long tube work (since that's another expense) but all the long tube + GT40P set ups I've read about have worked.
Depending on the headers, some people only have one or two pipes that are a problem for clearance. If that's the case, you may consider buying a spark plug boot adapater (can't think of a more specific part name at the moment). You can get these 90 degree jobbies that clip on the spark plug, turn 90 degrees, then have a male end for the boot to clip on to. They're kinda expensive to me, but a fraction of lube tubes, so if money is tight, that's an option. |
Threads Similar to: gt40 p heads
| GT40 or 351w heads | B.A.M302 | 5.0 Mustangs | 4 | August 20th, 2010 10:41 PM |
| GT40 Heads | fastford3388 | 5.0 Mustangs | 6 | September 29th, 2008 11:44 PM |
| GT40 heads vs GTP heads | 99TurboV6Stang | 5.0 Mustangs | 9 | September 18th, 2007 10:34 PM |
| gt40 heads.... | fastford3388 | 5.0 Mustangs | 4 | March 9th, 2007 06:49 PM |
| gt40 heads? | acg | 5.0 Mustangs | 4 | January 25th, 2007 10:14 PM |
