Re-torquing roller rockers need help!!!!
Old February 7th, 2009, 08:23 PM   #1
b-on-b 5.0's Avatar
1993 Mustang 5.0 LX
11.45@122.34
b-on-b 5.0 is on a distinguished road
I have a 1993 cobra longblock in my car and it came with 1.7 roller rockers from comp cams i just now got 4000 or so miles on the motor and one of the rockers on the driverside seems to knock louder than the rest at idle so i am guna re-torque everything back down but do not know the proper procedure for doing this so if anyone can help me i would greatly appreciate it.
Old February 7th, 2009, 08:28 PM   #2
86er's Avatar
nothing special just 18ftlbs and thats it
Just a truck
Old February 7th, 2009, 08:51 PM   #3
b-on-b 5.0's Avatar
1993 Mustang 5.0 LX
11.45@122.34
so i dont need to make sure any of the valves on the motor are closed when i tighten each one cuz i herd u have to make sure that it is on the flatest part of the cam when i tighten them??????
Old February 7th, 2009, 09:15 PM   #4
flamestang's Avatar
flamestang is on a distinguished road
that would be the logical way to do it
Old February 7th, 2009, 09:27 PM   #5
ryans88gt's Avatar
If it is making noise, it isn't a pedestal mount rocker issue, perhaps a collapsed lifter or flat spotted roller.
Old February 7th, 2009, 09:35 PM   #6
b-on-b 5.0's Avatar
1993 Mustang 5.0 LX
11.45@122.34
ok you dont think it is that bad of a problem then? becuz one of my buddies builds engines for street/strip cars and said it might have just lossened up from the facotry i am just guna re-torque them anyways to be safe...idk this guy knows his shit and the motors he build are lagit.....his car is in the low ten's at about 6,000 feet so idk i would just guess it was that i mean everything on the motor is new u really think there is a collapsed lifter or flat spot?
Old February 7th, 2009, 09:52 PM   #7
ryans88gt's Avatar
If an adjustable valve train rocker backs off it will make noise. If a pedestal mount rocker backs off enough to make noise the bolt will be completely loose and the rocker would fall off or break the bolt. Pedestal rockers do not adjust, they are either bolted down or not.
Possible sources of ticking noise
1) leaking header gasket
2) sticking injector
3) worn out roller on the lifter or rocker
4) misadjusted valve train (yours is nonadjustable, so if it came out of adjustment there is a underlying issue)
5) sticking valve guide
6) burned valve
7) collapsed lifter
8) bent pushrod
Old February 7th, 2009, 09:59 PM   #8
b-on-b 5.0's Avatar
1993 Mustang 5.0 LX
11.45@122.34
okm thanx i appreciate it yea i just talked to him and he said that its a possibilty that i have an exhaust leak but he said the sound is too minor to be a collapsed lifter or a flat spot i mean it sounds like a lifter to me but am guna check my header bolts and i am replacing the injectors so that is taken care of but maybe i will check for a leak first before tearing eveything apart
Old February 7th, 2009, 10:31 PM   #9
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
definitely check the exhaust..if its not a header..check the back of the head to cause i had this little plug back out, causing a leak...
Cohagan Engineering, Inc.
Old February 8th, 2009, 02:54 AM   #10
86er's Avatar
info isnt needed now, but now, set torque wrench to 18ft lbs and turn till it clicks, end of story
Just a truck
Old February 8th, 2009, 01:17 PM   #11
Pedestals suck.... You probably have the wrong rocker arm geometry
PeteAndersonRacing.com
Threads Similar to: Re-torquing roller rockers need help!!!!
Roller Rockers prodrifterx 99-04 6 January 4th, 2009 01:51 PM
Roller Rockers 95blackbeauty 5.0 Mustangs 1 June 17th, 2008 12:39 AM
1.6 or 1.7 roller rockers 89lx 5.0 Mustangs 6 June 14th, 2008 07:42 AM
roller rockers terribleonexx88 5.0 Mustangs 10 January 20th, 2008 11:14 PM
new roller rockers 03stanger 5.0 Mustangs 51 March 19th, 2007 10:50 PM
