When is a roll cage required?
Old January 5th, 2007, 10:08 PM   #1
82GT is an unknown quantity at this point
What E.T do they start requiring a 4 point cage?
1982 GT (t-top)
351w(.060),10:3, ported & polished iron heads, 1.94/1.60 valves, BBK shorties & flowmasters, 274XE cam, stealth intake, mallory dizzy, stealth intake, 750dp, Edge 3700 stall converter, C-4, 4:10's
Best E.T 12.85@102mph
Old January 5th, 2007, 10:11 PM   #2
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
well its a roll bar, a 6point roll bar is required in a coupe if you are running 11.49 and quicker, a cage actually goes forward into the dash and are 8-point, 12-point. but those are for 9.99-7.99
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old January 5th, 2007, 10:14 PM   #3
MM's nicest mod, :)
also look at my sticky in the 99-04 section for all the safety regulations
Old January 5th, 2007, 11:59 PM   #4
Stangzilla's Avatar
Stangzilla is on a distinguished road
11.49 or quicker requiers a 5pt bar minium. and a 8pt system does not go through the dash. 10pt cages go through the dash. and if you are running 11.49 or quicker you also have to have a quick release harness system. and the roll bar hoop must not be more than 6 inches from the drivers head with a helmet on and the rear hoop braces cannot be welded more than 5 inches from the top of the rear hoop. when in doubt buy the nhra book because as you can tell people think the now the rules and they dont...
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old January 6th, 2007, 09:48 AM   #5
what happens when you are at the track and dont know what your ride will run and you go faster than 11.49? Do they fine you or what?
Old January 6th, 2007, 09:50 AM   #6
5-0stank is on a distinguished road
i know where i race the guys there told my friend he couldnt race anymore that day. he came back w/o a cage again and they havent said anything
my friends have been in the 10's at atco raceway and there were no problems
1995 GT::Sold!
Looking for another stang...
Old January 6th, 2007, 09:53 AM   #7
cool, i guess if i ever get there, i will see what they say at my local track.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old January 6th, 2007, 10:38 AM   #8
Moderator
89StangGT's Avatar
SVT Cobra Mustang
89StangGT has a spectacular aura about89StangGT has a spectacular aura about
Send a message via AIM to 89StangGT
yeah at my track if you go 11.49 or quicker they tell you to put it back on the trailor or drive it home and dont come back without a cage or less mods.
There's a reason Ford codenamed them the Terminator
Old January 6th, 2007, 10:58 AM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Re: When is a roll cage required?
My advice would be to look into your future plans. A 6 point roll bar is required 11.49 (IHRA) and 11.99 (NHRA). If your future plans include going faster than that I'd recomend doing a 10 point roll cage right away. I'd recomend chromoly too if you can swing it because it is lighter and the resale value of the car will be higher as well.
Old January 6th, 2007, 11:27 AM   #10
Stangzilla's Avatar
As of 2006 rules its a 5 pt cage not a 6pt. and the way to get around the 11.49 thing if you are at a test and tune is when the light turns just wait a second or two after the light turns green then go. so if you usually run say a 11.30 and you wait 2 seconds you will run a 13.30!! take your timeslips home punch the numbers into a drag calc and you will know what you approx. run....
Old January 6th, 2007, 12:50 PM   #11
That won't work because each lanes timer doesn't start until you break the beam. I could set there all day after the green and it's only going to tell me what I ran after I break the timing beam.
The ONLY way around it would be to let off the gas before you go through the traps.
1982 GT (t-top)
Old January 6th, 2007, 03:08 PM   #12
Stangzilla's Avatar
so roll foward and break the beam then wait....
Old January 6th, 2007, 03:45 PM   #13
I'd rather install the bar. For me...it's run ALL OUT or not at all!!
1982 GT (t-top)
Old January 6th, 2007, 07:22 PM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That would defeat the purpose of going fast now wouldn't it
Old January 6th, 2007, 07:35 PM   #15
then ur 60' time would suck and would a calculator not use that to get ur time????
1995 GT::Sold!
Old January 7th, 2007, 03:08 PM   #16
that's the dumbest thing I've ever heard
88 Mustang Coupe
www.rickscarcare.net
Old January 7th, 2007, 03:31 PM   #17
MSO
MSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the rough
Send a message via AIM to MSO
yea i wudnt wait 2 seconds, jus nurse it goin down the track
if u wanna cheat that is
[SIGPIC][/SIGPIC]
Old January 8th, 2007, 12:24 AM   #18
Stangzilla's Avatar
nothin wrong with rollin foward a bit... does not defeat the purpose of goin fast.. he still ripped it!!!
http://videos.streetfire.net/categor...9d013e1438.htm
Old January 8th, 2007, 12:30 AM   #19
Yeah, that is okay, but i still think it defeats the purpose of having a fast car. We all know he went faster than a 14 second run, why not just get a cage and have your real numbers light up the time screen? Maybe he is cheap like me and didnt want to have to buy a cage so he found that route was better.
[SIGPIC][/SIGPIC]
Old January 8th, 2007, 04:07 AM   #20
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The only problem with that is there is not only an ET break down but also a mph break down. I'd have to look in the rule book but the rules state xx.xx et and/or xxx mph. Being lazy off the line will kill the ET horribly but it won't kill the mph at all.
Threads Similar to: When is a roll cage required?
roll cage install ttop5.0 Drag 12 September 7th, 2007 05:31 PM
05-07 mustang roll cage Norse1974 2005 - 2010 6 April 28th, 2007 02:51 PM
what speed do you need a roll cage? jessy_is_rad Drag 12 April 8th, 2007 03:09 AM
Roll Cage Photos needed turbong 5.0 Mustangs 0 January 19th, 2007 12:01 PM
Roll cage pictures for 65 Mustang Rusty105 General Tech 0 March 28th, 2006 06:22 PM
