omg that was gay
Old February 8th, 2009, 06:50 AM   #1
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
omg that was gay
but got it almost done in 14 hrs lol
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old February 8th, 2009, 07:08 AM   #2
moosenuk17's Avatar
2000 ford mustang GT
moosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the rough
Send a message via AIM to moosenuk17 Send a message via MSN to moosenuk17 Send a message via Yahoo to moosenuk17
14hours for a clutcha dn flywheel?
2000 kenne bell GT (440HP-432TQ)
Tuned by Joe at http://www.tricktuners.com
dyno vid:http://youtu.be/lr3xpxw2_v8
2011 escape
MUSTANG TAT CREW
Old February 8th, 2009, 07:19 AM   #3
chickenbot's Avatar
1990 mustang gt
eventually
first one ive ever done and i kept gettin side tracked.. also for the pilot bearing i didnt have a puller but never question a motivated marine and a cold chisel and a hammer lol.. that took 2 hrs
1990 gt 5.0
3.55 gears
Old February 8th, 2009, 07:44 AM   #4
moosenuk17's Avatar
haha sweet bro!
2011 escape
MUSTANG TAT CREW
Old February 8th, 2009, 07:50 AM   #5
chickenbot's Avatar
1990 mustang gt
eventually
all i have left is stab the tranny(after i clean it), drive shaft, and h pipe and alls good
1990 gt 5.0
3.55 gears
Old February 8th, 2009, 08:19 AM   #6
JBIGBOOTSY's Avatar
1990 LX hatch
You should open a shop. You'll make a killing on labor!
Old February 8th, 2009, 11:22 AM   #7
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
it took me a weekend to do mine and motor and tranny mounts.....i kept runnin into problems....the biggest one being the throwout bearing retainer was jacked up so we had to modify it
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old February 8th, 2009, 12:47 PM   #8
e3sean's Avatar
1988 lx
9.68@142
before you stab the tranny you need to pull the input shaft and check the mainshaft thats alot of play on the input shaft. call be before you pull it so i can walk you threw it or you will dump bearings inside the tranny.
<font size=4><b>MILITARY CREW
Old February 8th, 2009, 01:01 PM   #9
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
If you don't have a bearing puller then the next best thing is to pack the bearing hole with grease and use a dowel or bolt the same size as the pilot shaft. Just use a hammer to drive the dowel / bolt into the hole filled with grease, it will push the bearing right out.
Never fast enough.
Old February 8th, 2009, 04:01 PM   #10
notfastenuff is on a distinguished road
Aslong as it was done right
Old February 8th, 2009, 04:13 PM   #11
Nice 5.0's Avatar
1993
12.9 @ 105
Nice 5.0 is on a distinguished road
I tried that one time. I couldn't get it to work. I ended up buying the tool.
Old February 8th, 2009, 04:25 PM   #12
chickenbot's Avatar
1990 mustang gt
eventually
the old one was cast alum and it broke up pretty good
1990 gt 5.0
3.55 gears
Old February 8th, 2009, 05:17 PM   #13
Goblin's Avatar
88mm
Goblin will become famous soon enough
Send a message via AIM to Goblin Send a message via Yahoo to Goblin
Which stage is that Spec?
Old February 9th, 2009, 01:52 AM   #14
chickenbot's Avatar
1990 mustang gt
eventually
2nd
1990 gt 5.0
3.55 gears
Old February 9th, 2009, 01:54 AM   #15
chickenbot's Avatar
1990 mustang gt
eventually
finally done.. i cleaned up the tranny today too
before
after
1990 gt 5.0
3.55 gears
Old February 9th, 2009, 01:54 AM   #16
Glad to here you stuck with it and did it yourself......congrats
PeteAndersonRacing.com
Old February 9th, 2009, 01:58 AM   #17
chickenbot's Avatar
1990 mustang gt
eventually
thx the only thing im gonna fix tomorrow that i noticed what was the matter is a small exhaust leak on the drivers side and on the smog pump tube from the h pipe up
1990 gt 5.0
3.55 gears
Old February 9th, 2009, 01:59 AM   #18
chickenbot's Avatar
1990 mustang gt
eventually
lol i had to stick w/ it.. its my daily driver and i have to work tomorrow
1990 gt 5.0
3.55 gears
Old February 9th, 2009, 08:48 AM   #19
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
Good job man, go buy a slide hammer or make one it can be used for bearings or pulling dents the best $36 you will spend
Old February 9th, 2009, 09:59 AM   #20
baine21225's Avatar
before
after
.....hahaha those fucking shoes
Threads Similar to: omg that was gay
would this be gay... texas_mustang 2005 - 2010 49 February 10th, 2009 02:54 PM
This is gay Regency 2007 The Clubhouse 12 February 10th, 2009 01:49 AM
Omg Omg Omg Wtf AndrewA. The Clubhouse 5 June 6th, 2008 02:03 PM
GAY Juggalo_X The Clubhouse 19 November 21st, 2007 02:10 PM
how gay jagstang89 V6 Mustangs 42 January 17th, 2007 01:32 PM
