How much is a 100 shot of nitrous worth? - Forums at Modded Mustangs
post #1 of 12 Old January 5th, 2007, 10:08 PM Thread Starter
How much E.T do you typically gain with a 100 shot of nitrous?
If I was running 12.8's last year, will it be enough to get me into the high 11's?
2000 mustang 3.8
CAI, MAC duel exhaust.
82GT is offline
post #2 of 12 Old January 5th, 2007, 11:00 PM
Scoot'in
89Domindart's Avatar
Send a message via AIM to 89Domindart
I a m no experienced racer, but I have a 125 on my car. It typically will give u a second or so gain I think modestly I can say that. As long as you hook up.
I have a fuel inj 5.0 1989 manual mustang and is basically stock besides a NOS in the throttle body. It is like adding on another engine..lol its fast.
scootin
89Domindart is offline
post #3 of 12 Old January 5th, 2007, 11:08 PM
Stangzilla's Avatar
That depends on a lot of things. traction gearing vehicle weight with driver. I doubt you will hit 11's but you might cuttin it close with a 100 shot.. take your skirt off and put that 150hp jet in!!!
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Stangzilla is offline
post #4 of 12 Old January 6th, 2007, 12:11 AM
what kind of 60' times do u pull 82gt?
1995 GT::Sold!
Looking for another stang...
5-0stank is offline
post #5 of 12 Old January 6th, 2007, 01:41 AM Thread Starter
I pull high 1.6 60' times. I wasn't planning on hitting it until after the 60' mark because I still have 28 spline axles.
If everything looks good after a 100 shot, I might jet up to the 150 shot.
I only have hyper pistons so I have to monitor everything VERY closely!!
2000 mustang 3.8
82GT is offline
post #6 of 12 Old January 6th, 2007, 02:23 AM
Stangzilla's Avatar
fuel fuel and more fuel.. and some timing retard i think about 1 degree per 50hp...i think....
post #7 of 12 Old January 6th, 2007, 10:44 AM
Moderator
89StangGT's Avatar
Send a message via AIM to 89StangGT
whats your car run on spray? my 89 5 speed is a stock motor car and im looking to get some ideas on what it will run on the 125 shot.
2014 Ford Mustang Shelby GT500
89StangGT is offline
post #8 of 12 Old January 6th, 2007, 10:47 AM
1slo5.0's Avatar
Close to 1 second as long as the gearing and converter are tight enough.
1slo5.0 is offline
post #9 of 12 Old January 6th, 2007, 12:35 PM Thread Starter
I only have 4% converter slip so that's really good. I'm guessing I'll increase my trap speed by about 10mph? Sound about right?
Another thing I'm kinda worried about is my RPM's through the traps.
I'm turning 5800 and my cam makes power to 6200-6500. Nitrous is going to push me past that range on the top end...isn't it?
2000 mustang 3.8
82GT is offline
post #10 of 12 Old January 6th, 2007, 04:09 PM
Moderator
89StangGT's Avatar
how tall are your rear tires and what gears do u have?
post #11 of 12 Old January 6th, 2007, 04:57 PM Thread Starter
I have 26x9 slicks with 4:10 gears
2000 mustang 3.8
82GT is offline
post #12 of 12 Old January 6th, 2007, 07:18 PM
1slo5.0's Avatar
Try it and see where you end up. You will probably be around 6400 rpm and probably around 110 - 112 mph. Your converter should work pretty good.
1slo5.0 is offline
Human Verification
