#21 |
mine is on the outside, i have subframe connectors so its a full straight edge all the way back, i have clamps and rubber gromets that have it attached to the inside corner of the frame, its been like that for about 2 years now, no rubbing, no issues
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
#22 |
1993 Mustang
we'll find out when i come home from iraq.
glad to hear you haven't had any issues baine, but id keep it inside for peace of mind...
shut up before i punch you in the throat |
#23 |
1990 5.0 LX Notch
Yep I have seen pics of some others that have the run under the car.
#24 |
so are you saying i should move it?
#25 |
The Razor's Edge
no he is saying he isnt going to copy you
#26 |
1993 Mustang
exactly
#27 |
1990 5.0 LX Notch
#28 |
well do you think i should? the car is torn to pieces right now, it wold be the time to do it if i am
#29 |
The Razor's Edge
if its not broken dont fix it.....
the only reason i would put it in the inside is to keep it from rotting.....maybe something chewing threw it.....it could be 100 things... it just sounds like a better idea to not run a power wire under your car.....IMO |
#30 |
1993 Mustang
if it would be a big issue i would, like thunder said there are 100 different things that could affect it.
#31 |
Put it inside
PeteAndersonRacing.com |
#32 |
1990 LX hatch
I ran mine under the car, on the drivers side. Just use the metal and rubber clamps every foot. run it next to the frame rail. use rubber grommets for the holes.
#33 |
1989 Mustang LX
10.98@126.7 NA
I run #2 cable through blue flexible conduit to protect it. One nick or wear through and it's up in smoke Tommy.
Never fast enough.
#34 |
You can run it under the car, but run it along the frame rail away from the exhaust..
weeee foooord!
Threads Similar to: For w/ trunk mounted Batteries...
| how long are batteries lasting for yall | B0B | 99-04 | 23 | November 11th, 2008 09:32 PM |
| help! my batteries keep dieing!!!!!! | xtreme2own | 5.0 Mustangs | 13 | August 8th, 2007 06:08 PM |
| air filters and batteries help | 92stang0802 | 2.3 Mustangs | 9 | July 13th, 2007 09:19 AM |
