1990 5.0 LX Notch
For w/ trunk mounted Batteries...
Did you run the + cable through the interior or under? Also what side did you run it on?
1989 LX coupe 5.0L
i went on the inside on the drivers side along side the wires going back to the tails lights and what not
The Razor's Edge
any power wire should be kept away from weather as good as possible
1990 5.0 LX Notch
The Razor's Edge
i would make sure it wasnt rubbing anything either....if you cant help not to put something to relive the chaffing
1990 5.0 LX Notch
Hell there's nothing in the car now. It will be exposed (no carpet).
+1 - me too. Easy run, and there's a pass through up under the dash which pops out near the brake booster.
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
The Razor's Edge
best time to do it then...where you planning on grounding it?
1993 Mustang
we'll find out when i come home from iraq.
ehh it'll be fine, just make sure you run it w/ the exhuast lol
shut up before i punch you in the throat |
The Razor's Edge
fixt
1993 Mustang
1990 5.0 LX Notch
Tried that. Can't seem why it keeps melting the cable. Starting the get expensive.
1990 5.0 LX Notch
1993 Mustang
lol just get some of that heat wrap and it'll be fine, or run it under the car w/ duct tape
The Razor's Edge
stip the rubber off and run straight copper down the bottom of your car
#16 | |
1993 Mustang
yea it'd be a great insulator
The Razor's Edge
ground it just like you would a stereo amp
The Razor's Edge
start your car....get a bucket of water....touch wire and have fun
1990 5.0 LX Notch
Sounds good I'll strip the wire and run it under the car attached with duct tape right next to the fuel lines.
The Razor's Edge
you should wrap it around the fuel pump
Threads Similar to: For w/ trunk mounted Batteries...
| how long are batteries lasting for yall | B0B | 99-04 | 23 | November 11th, 2008 09:32 PM |
| help! my batteries keep dieing!!!!!! | xtreme2own | 5.0 Mustangs | 13 | August 8th, 2007 06:08 PM |
| air filters and batteries help | 92stang0802 | 2.3 Mustangs | 9 | July 13th, 2007 09:19 AM |
