351 Swap.`
Old February 10th, 2009, 09:06 PM   #1
1995 GT
WI5.0GT is on a distinguished road
Send a message via AIM to WI5.0GT
351 Swap.`
Here I go. I got a 351W here at home. What does it take to put in. Derict or is there alot to it
Old February 10th, 2009, 09:13 PM   #2
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
headers,oil pan, oil pump pick up
Old February 10th, 2009, 09:48 PM   #3
The Razor's Edge
White Thunder's Avatar
simple....what he said.....there are alot of threads about this
founder of the FTN Club
Old February 10th, 2009, 10:05 PM   #4
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
Um...more than that guys.
Headers
Oil pan AND rails
Oil pump and pickup (FRPP swap kit is best bang for the buck, 135 bucks)
351 Distributor
Lower intake if you have aftermarket intake, or a complete upper and lower
If you have stock heads, you will need to drill out the bolt holes for 1/2" bolts
The balance on 351s are 28oz. If you want to just swap it in, you need 28oz flywheel/flexplate and a 28oz balancer
A/C and P/S bracket or just P/S if you deleted the A/C
If its a roller cam, you need tie bar lifters or mod the block
longer pushrods
Extend the fuel rails
beer...
Old February 10th, 2009, 10:12 PM   #5
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all
iTrader: 13 reviews
Headers
Oil pan AND rails
351 Distributor
longer pushrods
beer...
Beer, it's a beautiful thing.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old February 10th, 2009, 10:42 PM   #6
86er's Avatar
86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold
a/c bracket is the only thing you need thats a different bracket
weve done 5 swaps and thats the only bracket that wouldnt/doesnt work fromt he 302
Just a truck
Old February 10th, 2009, 10:47 PM   #7
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
^ Really? So if you don't have A/C and you get the FRPP P/S 302 bracket...and you switch to a 351...you don't need the FRPP 351 swap bracket?
Old February 10th, 2009, 11:33 PM   #8
86er's Avatar
we have used the 302 stuff on all of our swaps, off the 302 that was in the car, I dont know if we have magic hands but the shit worked
Just a truck
Old February 11th, 2009, 10:23 AM   #9
1995 GT
but will it work with the 302 trans.
Old February 11th, 2009, 11:18 AM   #10
91 LX
13.7@101
what trans do you have
Old February 11th, 2009, 12:11 PM   #11
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
bellhousing patterns are the same. Yes, any tranny that bolts to a 302, it will bolt to a Windsor.
86er...tell me how an AC/PS bracket from a 302 fits a Windsor. The bracket(s) bolt to the water pump...the the upper bracket bolts to the head. Tell me how a bracket made for a 8.2 deck works with a deck of 9.5??? Now if you MADE it work, that's different...but a 302 bracket WILL NOT bolt on to a Windsor...period, that is why they make "swap" brackets.
Old February 11th, 2009, 02:05 PM   #12
89LX347's Avatar
89LX347 will become famous soon enough
who is the "we" you refer too?
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old February 11th, 2009, 08:17 PM   #13
1993 Mustang GT
Haggis13 is on a distinguished road
Send a message via MSN to Haggis13
Snufalofagous?
Bart
93 Black on Black GT
Kenne Bell S/C
GIVE 'ER!
Old February 11th, 2009, 11:52 PM   #14
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
^ yes....lol.
Hey bird....
Old February 12th, 2009, 03:37 AM   #15
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
how much hp can a 351w hold
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old February 12th, 2009, 04:04 AM   #16
89LX347's Avatar
it alll depends on how well its built. people on here will say in the 700's though
Old February 12th, 2009, 10:16 AM   #17
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
Well the weak point is the block. The crank holds quite a bit...and the block will split at some point just like the 302 block does at 500-600hp. I think the Windsor will start having problems around the 800ish range...
Old February 12th, 2009, 11:00 AM   #18
1998 Cobra
13.24@105.66
if someone is going to build an 800 hp motor, that aint going to be cheap.. why the hell would they use a stock block anyway? LOL
but yeah.. this topic has been covered in MANY threads, ill let others flame you.
weeee foooord!
Old February 12th, 2009, 03:43 PM   #19
1995 GT
Someone help me do my 351
Old February 12th, 2009, 04:03 PM   #20
89LX347's Avatar
what do you mean?
Threads Similar to: 351 Swap.`
1995 351 to swap or not to swap.& how to? Jeffery9508 94-95 9 August 3rd, 2008 09:00 AM
351 Swap FranMan 5.0 Mustangs 63 December 23rd, 2007 12:35 AM
351 swap ??? 95wip 94-95 17 April 4th, 2007 12:59 PM
351 Swap Cskit1500 5.0 Mustangs 6 November 16th, 2006 08:40 PM
351 swap 90ProjectStang 5.0 Mustangs 8 August 25th, 2006 02:47 PM
