wont start??
Old January 6th, 2007, 10:31 PM   #1
shadowgames81's Avatar
87 Coupe
shadowgames81 will become famous soon enough
wont start??
OK put headers and o/r h pipe on and started it up. Ran great no prob just smog pump blowin still and know I need to take it off but need to get eliminator first. problem is went out 5 mins later and now wont start. On top of that it pushes back but wont push forward. Thinkin maybe starter is locked engaged? no other clue why it wouldn't start now and only rolls backwards not fwd. any ideas??
Old January 7th, 2007, 01:37 AM   #2
mikebert is on a distinguished road
Send a message via AIM to mikebert Send a message via MSN to mikebert
Define "won't start".
Old January 7th, 2007, 01:41 AM   #3
87 Coupe
uh...power to everything fuel pump all acc but wont crank?
Old January 7th, 2007, 01:52 AM   #4
Define "won't crank".
Does it turn over? Do you hear grinding like before the engine starts to turn over? Does it just click? Do you hear nothing when you turn the key?
Old January 7th, 2007, 10:46 AM   #5
87 Coupe
like I said its not turning over no noise no nothing. everything powers up shows that it has full charge on batteryjust not turnin over at all
Old January 7th, 2007, 11:27 AM   #6
Bill is on a distinguished road
see if you can Jump the Starter relay. its right behind the battery on the driver side under the cover. take off the cover and get a screw driver. have the Key on but engine off. use that screw driver and touch both the big terminals on the starter relay and see if will start. if it does replace the Starter Relay solenoid.
may work or may not. just trying to help you narrow down problems.
and you can take off the Starter and take it to AutoZone or pepboys and have them check it for you.
is you car a 5spd or Auto?? what year??
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!!
Old January 7th, 2007, 01:17 PM   #7
Yep, go for that starter solenoid.
Old January 7th, 2007, 01:21 PM   #8
rodenberg's Avatar
rodenberg is on a distinguished road
use an old screw driver couse its gonna melt it a little you probably got the starter hot with the new headers tap it a little with a hammer (lightly) before you try anything more
bracket racing sucks
Old January 7th, 2007, 02:35 PM   #9
87 Coupe
well I did jump the solenoid this morning and it does start. replaced the solenoid for my friend and it still wouldn't start w/ the key so I jumped the solenoid again. Any ideas? Thinkin maybe his clutch safety switch went out but he just bought the car begining of dec. and he said that it has been starting w/o puttin in the clutch. Don't know if they bypassed it or not thas the only prob there.
Old January 7th, 2007, 09:22 PM   #10
82GT is an unknown quantity at this point
It could be a bad ignition switch. Ford is notorious for that.
1982 GT (t-top)
351w(.060),10:3, ported & polished iron heads, 1.94/1.60 valves, BBK shorties & flowmasters, 274XE cam, stealth intake, mallory dizzy, stealth intake, 750dp, Edge 3700 stall converter, C-4, 4:10's
Best E.T 12.85@102mph
Old January 7th, 2007, 10:10 PM   #11
solareclpse2000 is on a distinguished road
yea i would say check power to the ign. switch wire that leads to the solinoid
Threads Similar to: wont start??
Wont Start caintcatchmyGT 96-98 3 September 11th, 2007 12:02 AM
wont start snailstang 96-98 24 August 30th, 2007 10:46 AM
need help...car wont start orlyr21 V6 Mustangs 8 January 13th, 2007 09:17 PM
91-92 5.0 gt wont start sturcotte3 5.0 Mustangs 0 January 1st, 2007 06:40 PM
Need Some Help - Car Wont Start ANoXiA 2005 - 2010 6 December 23rd, 2006 07:07 PM
