Do 8.8 suspension parts fit 7.5 rear ends?
Old January 6th, 2007, 09:55 PM   #1
83 5.0's Avatar
83 5.0 is on a distinguished road
I know I should get a 8.8 but already over budget on my 83 Convertible 5.0 project, and my 7.5 is in great shape. I want to upgrade the springs and Upper/Lower control arms for now, will these parts fit my 7.5?
Will get an 8.8 eventually so would like to use these parts when I do get one, but want to improve the handling etc. as the original suspension is a V6 GLX, which is softer than air port limo's ride right now.
Thanks for any input.
Old January 7th, 2007, 01:20 AM   #2
'79 393 hatch
bigdog89129 is on a distinguished road
yes the suspension components are the same, I replaced my '79 7.5 with a 9'' but a 8.8 will bolt right in. Be sure its from a v.8. though if you want traction lock differential
Old January 7th, 2007, 05:02 PM   #3
82GT is an unknown quantity at this point
Also, in case you didn't know, the axles are the same for the 7.5 and 8.8 rears. I saved mine from my 7.5 when I did the 8.8 swap so that I would have some spares if I needed them in a pinch.
1982 GT (t-top)
351w(.060),10:3, ported & polished iron heads, 1.94/1.60 valves, BBK shorties & flowmasters, 274XE cam, stealth intake, mallory dizzy, stealth intake, 750dp, Edge 3700 stall converter, C-4, 4:10's
Best E.T 12.79@103.55mph
Old January 7th, 2007, 05:14 PM   #4
FastBack71 is on a distinguished road
whats the difference what are they
My friends used to wonder Why i joined the air force. Now they wonder why they didn't.
Old January 7th, 2007, 06:31 PM   #5
Nothing really but I was going to mention something about setting pinion depth for gears other than FMS but it's doesn't really matter 'cause he's having a shop install them amyway...
1982 GT (t-top)
Old January 7th, 2007, 08:20 PM   #6
83 5.0's Avatar
Thanks guys for the info, at least I will know how it handles before I spend the cash on a 8.8. THe car is just for cruising around etc., so I won't be stressing the 7.5
Old January 7th, 2007, 08:24 PM   #7
[quote="83 5.0 so I won't be stressing the 7.5[/quote]
Famous last words....
1982 GT (t-top)
Threads Similar to: Do 8.8 suspension parts fit 7.5 rear ends?
How much do you know about rear ends? Project_Stang 5.0 Mustangs 2 October 1st, 2007 10:33 AM
Switching rear ends. is it possible? from stock V6 to GT? cristo V6 Mustangs 16 March 6th, 2007 05:00 PM
Let's talk about rear-ends...lol postie V6 Mustangs 34 January 5th, 2007 02:32 PM
