Discussing Engine Popping in the 5.0 Mustangs Forum. Well it's me again and for some reason my stang is poping just sometimes ...
Old January 7th, 2007, 12:31 AM   #1
shawn91stang's Avatar
Engine Popping
Well it's me again and for some reason my stang is poping just sometimes when you get on it not all the time. Could it be the gas? I just checked my timing and it was 13 deg. So thats all good. I run the most i can get is 91octaine. I have an 88 i did a mass air conversion my computer A9L just went bad and I have a A9S now i have a 5spd could that be the problem? Or could it be a valve and how could I check to see if its a valve?
Old January 7th, 2007, 01:21 AM   #2
Where iss at?
weems's Avatar
2003 Mustang Mach 1
12.89@104.6
maybe an exhaust leak?
Beautiful
Old January 7th, 2007, 01:18 PM   #3
Stangzilla's Avatar
the most acurate way to check for valve sealing problems is to do a leak-down test and listen at the exhaust port and intake port .. unbolt headers and remove upper intake that way you can tell what cylinder it is coming from.. there might be an easier way but this way is for sure the way to know for sure... but not everyone has a leak-down tester..
The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.”
Old January 7th, 2007, 01:20 PM   #4
MuchCoolerThanGTsetGO
ChrisJ's Avatar
SLOW
Sounds like it is back-firing...
My Junk
www.myspace.com/cjobe
Old January 7th, 2007, 03:50 PM   #5
yea its like backfiring
Threads Similar to: Engine Popping
Exhaust popping energiesource 99-04 13 October 17th, 2007 08:42 PM
Popping noise? BrightWhite98GT 96-98 4 July 23rd, 2007 12:46 AM
Engine Popping shawn91stang 5.0 Mustangs 6 December 28th, 2006 08:48 PM
Popping out of 2nd weems Drivetrain 7 October 15th, 2006 11:57 PM
downshift 'popping'? ttop5.0 5.0 Mustangs 7 August 27th, 2006 11:04 AM
