Putting engine back together
Old February 13th, 2009, 07:47 PM   #1
1985 Mustang GT
viperlocc is on a distinguished road
Gonna throw things back together and i have just a couple questions:
1 - Engine has about 300 miles on it. When I put it all back together, should I just dunk the bearings in 30w oil?
2 - Timing. Of course everything will be TDC and lined up correctly. When I throw the dizzy back on and get ready to fire it up, can I just put it at 0 and work from their? or does it have to be advanced...and by how much? (mods below)
3 - Fuel. Still running a mech. fuel pump. To prep the system, do i just keep the pedal down and let it fill up that way or is their something else i should do?
306, e303, holley 600cfm, windsor jr heads, weiand stealth intake, 1" phenolic spacer
sorry if it seems like newbie question, but i am new to the v8/carb setup. built up some 4 bangers, I-6 turbo's, all fuel injected.
Old February 13th, 2009, 08:30 PM   #2
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
Well for what it's worth, I've never rebuilt my own engine but I've always heard people using assembly lube. I would assume thats the way you'd want to go.
Well I'm not sure what a "Dizzy" is, but i would assume starting from TDC would be your best bet, and then advance from there if necessary.
Finally, I'm not that familliar with carbs, or mechanical fuel pumps for that matter. But I would assume there's an easier way to prime the system before starting.
Hope others will post to help you out and if I'm wrong on anthing please, correct me. Good luck on the build.
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old February 13th, 2009, 09:26 PM   #3
1985 Mustang GT
Dizzy = Distributor
Assembly lube was used when the motor was first broke in. Do i really have to use more or can I just oil up everything and giv-er-hell
Old February 13th, 2009, 10:27 PM   #4
89LX347's Avatar
89LX347 will become famous soon enough
you should probably still use assembly lube seeing as how the motor is still pretty new.
start at 10 degres advance, it will start alot easier. pump the pedal a few times and make sure you prime the oil system just in case.
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old February 13th, 2009, 10:42 PM   #5
1985 Mustang GT
How do i go abouts setting it at 10* before i start it without one of those big dial indicators?
Old February 13th, 2009, 10:45 PM   #6
qwik48r's Avatar
alotta shit
no fat girls fast
qwik48r is a jewel in the roughqwik48r is a jewel in the roughqwik48r is a jewel in the rough
Send a message via AIM to qwik48r
with the distributor...
mind your business what i drive... i'm on a fucking mustang forum.
qwik's build
Old February 14th, 2009, 12:31 AM   #7
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
it doesn't matter if you start it at zero or ten
Old February 14th, 2009, 03:31 AM   #8
This is a disaster
PeteAndersonRacing.com
Old February 14th, 2009, 10:04 AM   #9
1985 Mustang GT
well, obviously. what im asking is doing it before the engine is started.
thats all i needed to know, thanks.
Originally Posted by 93mustank View Post
This is a disaster
sorry im not a pro like you. but if you have nothing good to say, please dont say anything at all.
Old February 14th, 2009, 10:53 AM   #10
1988 GT
Well I'm glad you got some input, hopefully your questions were answered. Keep us updated.
Old February 14th, 2009, 01:03 PM   #11
Not talking about you...Talking about the posters...
Why do you have the bearings apart???
If everything is together leave it together.
A drill and a socket works for me when priming the oil.
With the motor on a stand stabbing the "distributor" is very easy. You can watch the rocker movement and get tdc.
Line the balancer to zero and make sure you stab the distributor correctly.
Old February 14th, 2009, 01:36 PM   #12
1985 Mustang GT
Ah i got ya. Everything is apart cuz the block is at the shop getting the 2 holes drilled so i can make it a roller block. need em drilled for the spider.
I was told to prim the engine that way as well. thanks for the help
Threads Similar to: Putting engine back together
putting my plugs wires back on. Traidmarx 5.0 Mustangs 2 September 29th, 2008 06:50 PM
Thinking about putting a nissan engine in my fastback nba1341 The Clubhouse 39 May 16th, 2008 10:38 AM
putting the heads/intake back on tomorrow Devine 5.0 Mustangs 8 January 18th, 2008 02:10 PM
Putting in a new engine addict V6 Mustangs 13 February 7th, 2007 01:35 PM
Putting in cobra engine in Mustang GT oannamarie 96-98 10 July 10th, 2006 04:10 PM
