LinkBack (1) | Thread Tools |
#1
Is this a Moser axle?
looks like the famous 5 to 4 lug conversion, its hard to tell....looks like any other axle....can you find a part umber on it?
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
i highly doubt it. mosers usually dont rust that much around the center ring. also why does it matter? whats the spline count?
no one owns a moser axle?
1987 ford mustang gt
well see when shes done
First off many people on here own them.. Like stated most mosers dont rust that much around the center.. And why would you be worried about it if its bent?
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
#7 | |
Thanks. |
#8 | |
Authorized Vendor
![]() Join Date: Sep 2008
Not on a Ford, but on my Mopar 8 3/4" axle it has the Moser logos on the center caps. I'd be surprised if the previous owner had taken those off. That sure looks like a casting to me.
There's no way to tell from that picture... you need to find teh part number
48.47@ 12.58
Well here is how I see it.. unless you have a 7.5 inch rear.. why would someone upgrade all the way to moser and not pony up the cash for the few extra splines?
85 GT/86 SVO/2010 GT500
Moser axles will have M/E on the end not just a sticker it'd cut or engraved in the axle
1990 5.0 LX Notch
Also are the studs pressed in or screwed in? I know Strange uses screw in since the axles are hardened, I would assume Moser would do the same.
screwed in / all axles are hardend
1990 5.0 LX Notch
Well there is something done that will not allow you to use the press in studs.
Authorized Vendor
Not a Moser M, though.
I took another look at the axle I have, and I'd have to say that's a stock Ford axle. On a real Moser axle, the center area is machined and will look like it was turned on a lathe rather than cast. It's also not as deep. |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/110505-moser-axle.html
| What Does A Map Sencer Do In A 1991 Ford Ranger Ford Ranger 88 Rear End Ford Ranger Starting Problems | Championcar | This thread | Pingback | February 19th, 2009 12:00 AM | |
Threads Similar to: Is this a Moser axle?
| need help! moser axles! | mystang0673 | 99-04 | 10 | November 28th, 2008 11:03 PM |
| Moser Axles | blackhavok | 2005 - 2010 | 18 | June 17th, 2008 10:01 AM |
| Strange or Moser 31 spline axles? | 03 R Code | General Tech | 20 | September 5th, 2007 11:51 AM |
| Moser 31 spline axles | orangeRcode | 4V / SVT | 14 | February 6th, 2007 10:47 PM |
