Cam install problem...
So I installed new head gaskets, E cam and put back the stock rockers. Got everything back together and now when I start the car, it idles really rough and stalls. It won't stay running by itself. It's not backfiring or anything like that. Any advice?
did you change your vacuum lines most of the time they crack with age
Yea, I replaced them. If the distributor wasn't set right, would it have these symptoms? I am 99.99% sure I have it stabbed correctly. The car fires right up.
1982 GT t-top
no proof of purchase
Intake leak Or a massive vaccume leak somewhere?
Couldnt tell you....Would have to be there.... Where is your timing at???
PeteAndersonRacing.com |
sounds like a timing issue..
weeee foooord!
could be a stuck lifter (not saying it is for sure). just worked on my friends that had the exact same thing happen. it ran but idled like crap. did you put all the lash to 0? could also be a timing issue
1993 5.ohhhh
12.97 @140mph
When I put a cam in my car with stock rockers in did the same shit. I used the idle screw to raise the idle, which gave it an idle. At that point it fired up right every time. I then redid my timing starting with piston #1 at top dead center. When I did that and drove the car it finally idled right you could hear the cam, but made no power. Turned out my plugs werent in tight at all. But either way do what I said and it sounds like you'll have a running car in no time..
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
1989 GT
KB 2.1L Flowzilla
Carbed, MAF or speed density?
It's a MAF car. I was speaking with someone last night, and they said that the lifters need time to pump up. The timing is set at 10* with the mark on the distributor and the block. I am gonna check the lower intake tonight... I have a feeling that the rear seal slipped. I got a gasket set with the Fel-Pro blue seals that have a lip on them. Gonna install those tonight and see.
bump it up to 12* at least
#12 | |
Only usin a mark?????? There is your problem.........
The mark is a factory spot to set the timing to 10* before the motor is started for the first time. It is used for this purpose.
#14 | |
Figure out how to time your car first....then come back and report. Shouldnt ever do a cam install if you dont even own a simple timing light...
How am I wrong? I will take a photo of this and show you. And who said I didn't have a timing light? Read my OP and you will see that the car won't stay running. Before you give your $.02 you should understand the problem at hand.
Did you in fact use a timing light to time the car???
THE CAR WON'T STAY RUNNING, the vehicle does not run, the motor will not keep momentum, the air pump has seized to be... how else would you like me to put this?
Timing will cause the car not to run...did you in fact use a timing light?????????
lol, since you are messing with me your advice means nothing. i hope you can comprehend the fact that if an engine doesn't run, then a timing light doesn't do dick.
Your beating around the bush.... So you did use a timing light?????
Threads Similar to: Cam install problem...
| Cam install | usafimj | 2005 - 2010 | 35 | March 4th, 2010 07:01 PM |
| cam install | jerseymike | Modular Mustangs | 17 | June 27th, 2009 07:47 PM |
| CAM Install | MineralGreyGT | 99-04 | 50 | February 9th, 2009 08:55 PM |
| cam install? | Jucostud | 2005 - 2010 | 23 | October 12th, 2008 10:44 PM |
| E303 Cam Install Problem | 89BEAR | 5.0 Mustangs | 51 | October 30th, 2006 07:24 PM |
