Installing B303 & 1.7's
Old February 16th, 2009, 05:52 PM   #1
8994's Avatar
89 & 94 GT'S
8994 is on a distinguished road
Anything to consider when installing?
89' Blue & Silver GT w/ GT40 Upper & Lower Intakes,65mm t.b. 1.7 Roller Rockers,Shorty Headers,X -pipe, Flow
Master Cat back & Pony's for now....
94' Black GT 18" Cobra R's,leather and sunroof,Dynomax Cat back....
Old February 16th, 2009, 06:02 PM   #2
The Razor's Edge
White Thunder's Avatar
consider getting a better cam....
founder of the FTN Club
Old February 16th, 2009, 06:11 PM   #3
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
I would consider lifters and pushrods, depending on how many miles are on you're old ones. Possibly a fuel pressure regulator w/gauge. Othere than that it's a pretty mild cam, infact thats what I was running until a little while ago, good healthy idle, and decent rpm range. Enjoy.
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old February 16th, 2009, 06:38 PM   #4
Racinjason81 is on a distinguished road
maybe a timing chain would be a good idea while your at it.Lifters might be a good idea
but pushrods arent really necessary unless they are bent or worn but if your in there it wouldnt be a bad idea to do.
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old February 16th, 2009, 07:04 PM   #5
91 LX
13.7@101
the best idea would be to ditch the b303 cam and get something good. what else is done to the car?
Old February 16th, 2009, 07:04 PM   #6
91 LX
13.7@101
nevermind..i just read your sig. The b303 is going to yield very minimal gains...I would just do it right the first time and get a good anderson or comp cam or something
Old February 16th, 2009, 07:05 PM   #7
The Razor's Edge
hi jordan
i've heard nothing but good shit about anderson
Old February 16th, 2009, 09:38 PM   #8
89LX347's Avatar
89LX347 will become famous soon enough
i also recommend a better cam and these
Anderson Ford Motorsport Home Page
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old February 16th, 2009, 09:43 PM   #9
The Razor's Edge
i think the cam should be one of the last mods..to tie everything together
Old February 16th, 2009, 09:46 PM   #10
1987 ford mustang gt
well see when shes done
Originally Posted by White Thunder View Post
hi jordan
lol wrong person. I would not even waste my time with a b cam. I would just go with an anderson cam or even another off the shelf from some other cam companies.. I would just by an n-21 from anderson though.
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old February 16th, 2009, 09:57 PM   #11
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
You should learn now that "B" cam is a bad word around here, the same people and the same answers. Depending on your millage valve springs and timming chain.
Old February 17th, 2009, 12:14 AM   #12
1998 Cobra
13.24@105.66
e or f cam would be a wiser choice on the alphabet cams..
I personally like trickflow grinds, but different stroke for different folks.
I would consider new timing chain, lifters, and cam bearings if yours show lots of wear, usually they are ok.
Also check the pushrods for straightness by rolling them alongside a straight edge with a venier caliper
weeee foooord!
Old February 17th, 2009, 08:56 AM   #13
8994's Avatar
89 & 94 GT'S
I already have the B cam but I will consider others... I'm just concerned about valve 2 piston clearance since I have 1.7's..
Old February 17th, 2009, 09:34 AM   #14
M L Struck's Avatar
I have done that same combo 4 or 5 times in years past just make sure your rockers are good quality,I have only done this with Ford and Crane rockers. As far as the cam bearings go, not a consern
Threads Similar to: Installing B303 & 1.7's
New Here..Quick ? (1.7's) 8994 5.0 Mustangs 0 February 14th, 2009 08:39 AM
installing amp/sub to stock mach headunit Slow_Stang 99-04 11 December 6th, 2008 11:23 PM
installing an amp cthall30@verizon.net Audio/Video 4 April 6th, 2008 08:45 PM
INSTALLING AN AMP 1BADSTANG Audio/Video 1 October 1st, 2007 10:29 PM
installing an amp 1BADSTANG 5.0 Mustangs 0 September 29th, 2007 10:45 PM
