1985 Mustang GT
Should I use this?
lookin around at different assembly lube
Edelbrock 9260 - Edelbrock Cam and Lifter Lube - JEGS will 2 of these be enough for the cam/lifters/rockers/main bearings/rod bearings? i also read that people just use assembly lube on the cam, and just standard oil on everything else.. |
The Razor's Edge
its cheap so why not....wait for the experts and see what they say
1985 Mustang GT
oh, and what mechanical fuel pump should I get? only running a 600cfm on top of a 306. 130gph? or less? thinkin the holley 110gph will do me good.
The Razor's Edge
wait one
2000 mustang GT
85 GT/86 SVO/2010 GT500
Royal Purple RP01335 - Royal Purple Max-Tuff Assembly Lube - summitracing.com
Make sure you use this for start up you have to have the high zinc Royal Purple RP11487 - Royal Purple Break-In Oil - summitracing.com |
1987 ford mustang gt
well see when shes done
royal purple lube works fine as well as white lube.. You can use a conventional oil to break you motor in also, thats all the royal purple is..
You need somthing with high zinc content, the newer conventional oils have done away with zinc in the formulas. ask any good engine biulder. I am just trying to save you time and money.
When you become an engine builder tell me what i need to use.. lol
I used conventional 10 30 to break my motor in and it seems to be fine..
I'm glad that one engine is what you base your info on.
First of all i was messing with you hint the
and second of all that was an example.
I was LOL I just didn't tell you, now even more, just screwin with you
#13 | |
1985 Mustang GT
ended up going with a 110gph mechanical pump, royal purple assembly lube and non-synthetic engine oil for the initial startup (engine already has 300 miles on it when first put together) had to take it apart (bought it rebuilt) so i could make it a roller block |
