1991 Mustang GT
The Oil Dipstick?
I bought a 1991 Ford Mustang GT, and the person who i bought it from put BBK shorty headers. And the dipstick for the oil was not bolted down and just hanging out. And i can not find out where it goes? What do i do?
1988 GT
As far as I remember it gets bolted inbetween the header and header bolt.
1994 GT
yea, u have to take one of the header bolts out..it is the second one from the back of the motor..well i got a 94 but i think its the same
Cohagan Engineering, Inc. |
1991 Mustang GT
yeah, i can't find the hole in the motor where it goes!
are you talking about where the dipstick goes into the oil pan or where the tube that the stick is in bolts to the motor
1990 LX Coupe
The dip stick mount, mounts to the header bolt. There is a header bolt that looks like a stud and you just put a nut on it.. Problem solved
1991 Mustang GT
Where the dipstick tube goes in the oil pan?
i think it is welded to the pan or something from the factory...but it should have a tab that you can put a header bolt through and that will hold it in place on the side of your block. post a pic or somethin
Dip stick doesnt go in the oil pan...goes in the block.
PeteAndersonRacing.com |
Atomized
where it goes into the block it's just pressed in. it's a pretty shit design for sure
1992 Lx
11.39@119.24
its really hard to see, when your cars cool stick your hand down between cylinders 7 and 8, its under the headers just feel around for a bit, the dipsticks bolted to the 4th header bolt back from the front on cylinder 2
12.8@103... stock motor
11.8@113...150 shot
the dipstick tube does bolt to the headers, but that gets in the way when you're changing plugs, i'd recommend bending the tab and bolting it down using a valve cover bolt...
1991 Mustang GT
I have one more question the dipstick is curved and not straight. So i wanted to know if it is the trans or for the oil? Witch one is straight and witch one is curved?
the trans fluid stick will be on the passenger side and will have red fluid. oil is on the driver side and will have blackish fluid
my dipstick tube uses one of my valve cover bolts
Threads Similar to: The Oil Dipstick?
| Oil pan dipstick provision | wraitherx | 99-04 | 15 | July 16th, 2008 11:17 PM |
| Oil level on dipstick | willsurforbeer9 | V6 Mustangs | 2 | January 26th, 2008 06:22 PM |
| help with oil dipstick on 97 cobra | rubberdown | Modular Mustangs | 1 | October 18th, 2007 11:57 PM |
| oil dipstick | dr.gonzo! | 5.0 Mustangs | 2 | March 30th, 2007 05:02 PM |
| Alternate Oil Dipstick? | chaderpiller | 99-04 | 1 | September 9th, 2006 09:31 AM |
