Solid roller cam??? - Page 2
Old February 20th, 2009, 08:08 AM   #21
e3sean's Avatar
1988 lx
9.68@142
Originally Posted by flamed 98 gt View Post
Just have always loved the sound of them.
if its the sound you like then you want a flat tappit lifter not a solid roller. but yes dont make sound a goal make it a positive bi product of power.
<font size=4><b>MILITARY CREW
Old February 20th, 2009, 12:41 PM   #22
ryans88gt's Avatar
hydraulic lifters can have two problems at high spring pressures and high rpm
Lifter collapse, which is when the plunger collapses and you get excess valve train noise. This can hurt pushrods, rockers and the cam from having too much lash in the valve train. It will not hurt pistons and valves.
The other problem is lifter pump up, which is when the lifters can't bleed enough oil out under high rpm and push the plunger up to the retaining ring removing all preload from the lifter. This causes the valves to open 0.020-0.030" further than they would normally and to not close completely. This results in loss of power from the valves not closing but will not cause damage unless you are running an extremely too tight PTV clearance.
Advantages of solid roller is basically that you don't have to worry about the above two problems and can run a lot higher spring pressure and thus ramp rates of the cam can be more agressive. The down side is more maintenance and shorter valve train life (especially with monster springs). However, you can get a tight lash street roller that will last a long time with reasonable springs and direct oiled roller lifters.
Old February 20th, 2009, 04:34 PM   #23
e3sean's Avatar
1988 lx
9.68@142
good description ryan. i am always learning a thing or 2 from your write ups. i may have to put u to work when u get here lol j/k
Old February 20th, 2009, 05:40 PM   #24
JBIGBOOTSY's Avatar
1990 LX hatch
Originally Posted by M L Struck View Post
Hey, Darrell what is lifter float?
+1 I thought "lifter float" was "lifter collapse"
I can find much info on lifter float, Ive heard the term, but cant find much.
I'm pretty positive that "lifter float", and "valve float" are not the same thing.
Old February 20th, 2009, 06:19 PM   #25
ryans88gt's Avatar
I would think any kind of float is when the spring can no longer control the valve train motion. So lifter float would be when the lifter comes off the cam lobe because the spring can't hold it down?
Darrell has been MIA for awhile.
Old February 20th, 2009, 07:58 PM   #26
1990 5.0 LX Notch
flamed 98 gt is on a distinguished road
Not only going just for sound, I just think they sound great. I was looking at them for performance reasons.
Old February 21st, 2009, 03:03 AM   #27
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
last i heard from him was on the 16th
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Threads Similar to: Solid roller cam???
347 solid roller cam build up slowta 5.0 Mustangs 17 February 19th, 2009 10:26 PM
Solid Roller vs. Hydra Roller Goblin 5.0 Mustangs 58 November 30th, 2007 02:22 PM
Hydrolic roller to Solid/Mechanical roller hitorx 5.0 Mustangs 2 May 14th, 2007 05:12 PM
