1990 5.0 LX Notch
Solid roller cam???
I did use the search button but could not seem to find answers. What is the differece between a solid roller and a hydrolic roller cams. I have a 1990 5.0 lx that saw maybe 200 miles last year. This car is more strip then street and I have thought about doing the swap. What all is needed and is there any advantage to the swap?
What rpm do you wanna spin ???
PeteAndersonRacing.com |
you know there is a thing called google
Re: Roller vs hydraulic Cam here is a good little article about it. go through and read this one too, lots of good info Solid Roller Cam vs. Hydraulic - Corvette Forum
85 GT/86 SVO/2010 GT500
the advantages to going with a soild over a hyd. is the much higher RPMs you can rev without valve float, with a solid. In general most solid roller motors are pretty high hp
i got a decent sized hydr roller cam im tryin to sell, pretty cheap too, never used
1990 LX hatch
Valve float is from the springs. you might be meaning lifter float, but that cant damage your pistons. Solid lifters are... solid, and do not have give. Solid lifters require far more attention to valve train setup, and adjustment.
1990 5.0 LX Notch
1990 5.0 LX Notch
thats the exact cam I want, id trade you straight up if you are interested in the cam I told you about
Why buy or install a cam based on sound?????? Seems hog wash to me...
If you are talking to me, its not based on sound, its got the decent split in duration I want for the nitrous and its got enough lift when added with my 1.7's to keep the lift values where my heads flow max cfm...........
To original poster
If valve float can damage pistons so can lifter float,it's the same action just at the other end of the valve train, it is the lifter losing contact with the push rod due to high valve train speed valve float is the valve losing contact with the rocker arm.Either way the movement is out of time with the piston
#14 | |
1990 LX hatch
Umm no if the spring fails and the valve floats, the pistion hits it, if the lifter floats the valve still closes, there is just a gap between the rocker and cam.
1990 LX hatch
I dont get it... Lifter float is when a hydraulic lifter stays collapsed. This will not keep the valve open.
Valve float is when the spring does not have time or tension enuf to close the valve. This will keep the valve open. That article states that valve float and lifter float are the same thing, I can tell you that they in fact are not.
lifter problems when collapsed put slack in the valve train, the tapping you hear when a lifter drops is the push rod tappin the rocker before it pushes it open, as much as they suck a dropped lifter is safer to have go wrong than valve float
#18 | |
1990 LX hatch
I allways thought lifter float was when the spring inside the lifter stayed compressed, just like when the valve spring stays collapsed. Im pretty sure your talking about pump-up.
Hey, Darrell what is lifter float?
Threads Similar to: Solid roller cam???
| 347 solid roller cam build up | slowta | 5.0 Mustangs | 17 | February 19th, 2009 10:26 PM |
| Solid Roller vs. Hydra Roller | Goblin | 5.0 Mustangs | 58 | November 30th, 2007 02:22 PM |
| Hydrolic roller to Solid/Mechanical roller | hitorx | 5.0 Mustangs | 2 | May 14th, 2007 05:12 PM |
