Need plugs and wires
Old February 17th, 2009, 04:22 PM   #1
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
My vortech is on! Just got done putting the upper back on after installing 42lb injectors. Just need plugs wires and a belt to get this mother going.
I have gt40p heads... so I need colder plugs. Which to go with. What plugs wires would be suggested as well.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old February 17th, 2009, 04:31 PM   #2
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
Go with autolite plugs and Taylor wires
Old February 17th, 2009, 04:50 PM   #3
1993 5.ohhhh
12.97 @140mph
What autolites though? How cold?
Old February 17th, 2009, 05:39 PM   #4
M L Struck's Avatar
Autolite 34's
Old February 17th, 2009, 05:47 PM   #5
1993 5.ohhhh
12.97 @140mph
And these wont be an issue for p heads? also with the boost, what should I gap them at?
Old February 17th, 2009, 07:08 PM   #6
The Razor's Edge
White Thunder's Avatar
one step colder than stock and i would take the gap down to .035 - .040
founder of the FTN Club
Old February 17th, 2009, 09:36 PM   #7
86er's Avatar
prob closer to .032-.035 and 8mm taylors should run about 50 bucks 10.4mm around 100 bucks
murrys should have them in stock
Just a truck
Old February 17th, 2009, 09:55 PM   #8
1993 5.ohhhh
12.97 @140mph
Are the taylors worth it? honestly...
Old February 17th, 2009, 10:03 PM   #9
1998 Cobra
13.24@105.66
with boost, you need good ignition. do it right the first time.
weeee foooord!
Old February 17th, 2009, 10:16 PM   #10
1993 5.ohhhh
12.97 @140mph
good answer... im running stock ignition with a blaster coil, so I suppose that makes sense. I got a good hook up at murrays down here thank God.
Old February 17th, 2009, 10:19 PM   #11
The Razor's Edge
the better the wire the less resistance....so they are indeed worth it
msd also makes some good wires
Old February 17th, 2009, 10:22 PM   #12
86er's Avatar
from what ive seen the 30 extra bucks for msd, wasnt worth it
Just a truck
Old February 17th, 2009, 10:23 PM   #13
The Razor's Edge
i had a test sheet somewhere of the major wires tested and i cant find it...msd was at the top taylor wasnt tested....i'll keep looking
Old February 18th, 2009, 07:47 AM   #14
M L Struck's Avatar
Set your gap at about .035
Old February 18th, 2009, 10:56 AM   #15
91 LX
13.7@101
i spoke with a guy who is a salesman for a company that makes distributors and plug wires (custom) mostly does work for race car drivers who need certain sizes etc. He said the plug wire that comes closest to being as good as his is MSD. He has ran all sorts of different tests. I forget the name I will stop in the shop and find out. The distributor he makes is supposed to be awesome too it doesnt retard barely any timing, the MSD does along with the others. Just thought it was pretty cool...when he put his plug wires on the c6 corvette we were tuning...you could tell a difference in the idle w/ open cutouts
Threads Similar to: Need plugs and wires
Spark Plugs And Wires? 909mustangx2 96-98 1 February 1st, 2009 01:38 PM
Plugs and Wires RavensChild 96-98 7 October 19th, 2008 11:12 AM
Spark plugs and wires BDaily V6 Mustangs 4 June 8th, 2008 08:19 PM
plugs and wires dragpipe General Tech 6 April 11th, 2007 02:25 AM
plugs and wires QuEeNiEsTaNg V6 Mustangs 4 February 7th, 2007 09:39 AM
