Need help stat!!!!!
Old February 18th, 2009, 02:55 PM   #1
88 Mustang GT
jcarter8432 is on a distinguished road
Need help stat!!!!!
I was in the process of installing long tubes and i unbolted both motor mounts(stupid me). i got my passenger side in and went to dop the motor back down and now my motor mounts arent lining up. in the process of all this the motor moved itself more towards the drivers side. Nothing i do gets the motor moved in the right direction. I need help guys before this thing slips and crushes my oil pan. Any ideas?
PS the engine loops attached to the headers arent attached so hoisting it and sliding it over isnt gonna do it.
88 GT, fenderwell cold air, 75mm maf tb egr, gt-40 intake w/ 1" spacer, 24lbs inj. & 190lph fp, 3g alt., t56, lowered 1.5, lt's o/r x and 2chamber flows, 3.73 w/ trak-lok carbon kevlar rebuild
Old February 18th, 2009, 03:01 PM   #2
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
Big ass pry bar and a helper
Never fast enough.
Old February 18th, 2009, 03:08 PM   #3
88 Mustang GT
so jack up the motor and pry it over. ill see what i can do.
Old February 18th, 2009, 03:10 PM   #4
If your using a cherry picker try hooking the chain left or right....
PeteAndersonRacing.com
Old February 18th, 2009, 03:16 PM   #5
Rage Wraps is on a distinguished road
Pry bar, move the chain, get a helper. There is no easy way of getting it in.
Old February 18th, 2009, 03:20 PM   #6
88 Mustang GT
yea that i know. its only moved a little, but everything i tried so far seemed to move it more in the wrong direction.
Old February 18th, 2009, 06:19 PM   #7
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
get a jack under the oil pan....but a piece of wood like a 2 x 4 or something between the pan and jack
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old February 18th, 2009, 07:49 PM   #8
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
+1 this is the easiest way. If your jacks on wheels just roll it the way you need it.
Old February 18th, 2009, 11:50 PM   #9
88 Mustang GT
i got it. jacked it up on the side to get it to slide in the direction i needed it to go, grabbed the pry bar and started yanking. it took my brother lettin the jack down while i was prying a few times to get it to slide in the right direction, but a couple of yanks n it was done. now i gotta wait until the ground dries to get the other side done. thanks for the help guys.
Threads Similar to: Need help stat!!!!!
t-stat njstang 99-04 8 August 31st, 2008 04:45 PM
Installing HID kit: Newb Stat. ixmotoxi 2005 - 2010 0 August 5th, 2008 11:49 PM
