can some one please help me with my super charger set up
i just purchased a used powerdyne supercharger system, it came with instructions but it does not say anything about having to have a blow off valve. i have a stock 5.0 coupe, and i need to know what all i need to get it going, i also need to know if there is suppose to be a gasket between the compresser housing and the charger ?
are you asking if you need a blow off valve?
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
yes and i need to know if there is suppose to be a gasket between the compresser housing and the charger ?
by pass valves help to prevent losing power at part throttle situations... I don't think base kits came with them but I never liked powedynes personally so I never paid too much attention to them. I'd say if it's going to be putting out more then 6lbs of boost then you need a bypass valve, just go to somewhere like superchargersonline.com and order one to suite your needs
have no idea about the gasket as i've never touched a powerdyne unit |
you wont need a blow off valve even at 10 pounds with that supercharger, although i wouldnt recommend goin up to that psi.
1993 5.ohhhh
12.97 @140mph
That powerdyne wouldn't make 10psi if it tried.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
I believe Vortech recommends a bypass when going above 6#.
My own question.. A blow-off dumps metered air, does that cause noticeable issues because of spiked changes in A/F ratios? A lot of people use them so it must not be a problem?
1988 GT
Do you know what kit youh purchased? and with which blower? Maybe this will help... Powerdyne - Application Chart
1993 5.ohhhh
12.97 @140mph
the blow off on a centri blower wont work. It will run like total dog shit.
i dont think i quite understand your question? the blow-off valve shoots all the air that stays in the inlet tube when the throttle body slams closed out, and sometimes it has a tube from the blow off valve goin back to the power pipe to re circulate the air. maybe that will answer your question
You didn't
![]() A blow-off sends air that was metered and calculated by the mass air sensor out to the atmosphere. A bypass sends it back to the suction of the S/C. Does the fact that using a blow-off throws metered air out of the intake mess with or cause spikes in the A/F ratio and is that a problem or is it too short of thing to even matter? I have a bypass and it works fine, I am just wondering if there any side effects with using a blow-off.
#12 | |
1988 GT
Threads Similar to: can some one please help me with my super charger set up
| Super Charger, Turbo Charger Effects? | Gtwrestler | Modular Mustangs | 15 | June 9th, 2009 07:02 PM |
| super charger?? | the88-5.0 | 5.0 Mustangs | 1 | July 13th, 2008 08:04 PM |
| Super charger VS turbo charger | stinglikeastang | V6 Mustangs | 25 | July 23rd, 2007 10:24 PM |
| Super Charger | cboog25 | V6 Mustangs | 11 | October 17th, 2006 09:56 PM |
