1992 Mustang GT
Coming soon...
Picking injectors?
Motor is about done, just gotta pick up pushrods and some rocker arms. Specs: 306ci, srp forged flat-tops, comp xe-270 cam, performer intake, gt40p heads, etc. Looking to get a set a new set of injectors because I think I will be close to maxing out the 19lb'rs. Since I plan on spraying(100-150 hp dry shot) this summer, I was wondering what size to get? Until then, it will be naturally aspirated, though.
Thanks
1992 Hatch: 306ci, gt40p's, comp xe270, Edelbrock Performer, 1.6 r/r, full bolt-ons, and some supension work Last edited by Burn'nRubber; February 19th, 2009 at 01:13 AM. |
good rule of thumb for 19lb injectors are 300hp..
I would put some 42lbs in there and be done with it. Those will flow enough fuel for whatever spray you want to use.
weeee foooord!
woah 42's? no no no. thats way over kill. put the 24's and you will be good.
1993 5.ohhhh
12.97 @140mph
If you decide to go go 30lbers let me know. I have a pair for 100 bucks used.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
what is your overall hp going to be?
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
1992 Mustang GT
Coming soon...
I really dont know, im hoping for around 280-300hp N/A, and eventually the 150 shot on top. So roughly 400-450hp on the smack.
1992 Hatch: 306ci, gt40p's, comp xe270, Edelbrock Performer, 1.6 r/r, full bolt-ons, and some supension work |
well with 450 flywheel and a .57 b.s.f.c. and 90% of max duty cycle thats about a 35 lb/hr injector
yeah 30's should be ok for what you will be doing
I wouldn't go as big as 42lbers unless you absolutely have to.. I can't stand the hard start conditions the green tops give. Requires a little more tuning to cure that issue
#10 | |
weeee foooord!
1989 LX coupe 5.0L
heres a chart i used
1992 Mustang GT
Coming soon...
Thanks every1, prolly going to go with either 30's or 36's.....
if its between those two then get the 36
remember you can use a smaller injector and bump up fuel pressure a hair.
weeee foooord!
30#'s would be more than enough for what you are doing. Make sure yu have a decent pump in the back. Walbro 255 intank would be nice.
Threads Similar to: Picking injectors?
| Picking a name for the new GT | coolhandluke | 2005 - 2010 | 6 | June 26th, 2008 04:08 PM |
| Need Help Picking | Juggalo_X | The Clubhouse | 56 | December 19th, 2007 04:56 PM |
| Picking Your Fights | Joey304 | Racer's Corner | 25 | December 19th, 2006 10:32 PM |
| I Need Help Picking A Sub | zchriz | Audio/Video | 11 | November 22nd, 2006 11:20 AM |
