Discussing 351 windsor in the 5.0 Mustangs Forum. hey what's up new to the forum,i just bought a 351 for 50.... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
351 windsor |
if u search by motor it is very easy
1995 GT::Sold! Looking for another stang... |
CRN-443941 $115.99 Brand: Crane Cams Product Line: Crane PowerMax Camshafts Cam Style: Hydraulic flat tappet Basic Operating RPM Range: 2,000-5,000 RPM Intake Duration at 050 inch Lift: 216 Exhaust Duration at 050 inch Lift: 228 Duration at 050 inch Lift: 216 int./228 exh. Advertised Intake Duration: 272 Advertised Exhaust Duration: 284 Advertised Duration: 272 int./284 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.484 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.512 in. Valve Lift with Factory Rocker Arm Ratio: 0.484 int./0.512 exh. lift Lobe Separation (degrees): 112 Intake Valve Lash: 0.000 in. Exhaust Valve Lash: 0.000 in. Computer Controlled Compatible: No Grind Number: H-272-2 CARB EO Number: D-225-32 Quantity: Sold individually. Camshaft, Hydraulic Flat Tappet, Advertised Duration 272/284, Lift .484/.512, Ford, Small Block, Each |
Threads Similar to: 351 windsor
| windsor or BB? | sloppyjosey | 5.0 Mustangs | 18 | October 26th, 2007 01:25 PM |
| 351 windsor | Iownastang | 5.0 Mustangs | 7 | July 24th, 2007 01:36 PM |
| 5.8 windsor | gt40 1966 | 5.0 Mustangs | 2 | July 5th, 2007 10:57 AM |
| 351 Windsor HP? | 351W94GT | 96-98 | 11 | June 29th, 2007 09:14 PM |
| 351 Windsor | dragpipe | General Tech | 5 | February 28th, 2007 07:40 PM |
