1990 mustang gt
eventually
sn95 e fan
will this fit?
![]() ![]() ![]() and does anyone know how to wire this to work?
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
just take a 9v battery and run a wire to each of the prongs and remember which way turns it.
Should work fine, might need to trim the fan shroud a little
weeee foooord!
1990 mustang gt
eventually
fuck.. its not gonna fit.. its too thick.. i only have 4.5" from radiator to water pump pulley and the fan is 5" thick
1992 Lx
11.39@119.24
my fan sits to the side a lil so the water pump and the fan motor arent lined up, and those 3 prongs are the high and low speeds, one is a ground im guessin
1990 mustang gt
eventually
do they make thinner water pumps?
honestly just find one that fits, not really worth making a stock cfm fan work.
weeee foooord!
1992 Lx
11.39@119.24
you cant put it kinda to the side so the fan motor and water pump arent touchin?
1990 mustang gt
eventually
i put it off to the side but then the fan wasnt covering all the radiator.. the fan was like 1/4 off of it
Notch the core support and pull the rad back half inch
weeee foooord!
1990 mustang gt
eventually
is there any way i can push it further? i dont have a condenser in there anymore
#11 | |
1992 Lx
11.39@119.24
so? thats most of it, mine doesnt cover the whole thing
Threads Similar to: sn95 e fan
| sn95? | mustang fanatic | 99-04 | 4 | May 4th, 2008 04:50 PM |
| Taurus fan vs Mark vlll fan | black88 | 5.0 Mustangs | 1 | September 20th, 2007 07:57 PM |
| sn95? | cdunc24 | 5.0 Mustangs | 2 | January 12th, 2007 07:11 PM |
| electric fan vs fan clutch | hmotes | 5.0 Mustangs | 8 | December 19th, 2006 02:03 AM |
| Electric fan or Flex fan? | vivoronte | 5.0 Mustangs | 20 | February 10th, 2006 10:58 PM |
