1991 Ford Mustang LX
Help Electrical
Ok so heres the deal, a few months ago my car started to have a bunch of random "misfires" where the rpms would sporadically drop. In the process of fixing that problem i replaced the tfi, tps, wires, plugs, coil, fuel filter, fuel pressure regulator, and cap and rotor. Finally i found it was the actual distributor all along and replaced that wiht a advance auto reman one.
10 mins after replacing it the car died, pulled a plug no spark what so ever. Wires to coil are good, coil is good. Must be a bad dizzy right? The car will start up cold, run till hot and die and not restart till cool again. Any ideas please help.
BBK CAI and Shorty Headers, Cobra Upper/Lower Intake, Walbro 110, 24# Injectors, larger throttle body, maf, Drilled and slotted front rotors, King Cobra clutch, Cobra wheels w/ sumitomo tires, flowmasters |
help please
1988 GT
Check out the sticky on setting base idle.... maybe that will help you out?
1990 mustang gt
eventually
tfi
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
it was a defective reman dizzy
at least this 5 month project is over...
1988 GT
good to hear
Threads Similar to: Help Electrical
| need electrical help!! | Kev90stang | 5.0 Mustangs | 1 | August 4th, 2008 11:45 PM |
| Electrical Help | JDMILLS | Classic Mustangs | 3 | March 7th, 2008 07:48 PM |
| electrical help | bobb17 | 2.3 Mustangs | 10 | February 10th, 2008 11:27 PM |
| Electrical help... | joeice14 | 2005 - 2010 | 8 | January 30th, 2008 01:34 AM |
| Need Electrical HELP!!! | monkey187 | Audio/Video | 8 | March 19th, 2007 10:41 PM |
