rebuild almost done one question
so ive been working on this motor for two months now and have it nearly done. here is what i have so far
kb forged pistons total seal rings scat i beam rods clevite 77 bearings re-ground stock crank and flywheel this is .30 over by the way the question is heads i am looking to run 10-12 pounds of boost after a month or two so i am going to want lower comp. i am thinking afr 185 heads should do the job but not sure and i have already put a 7 qt canton pan with a girdle and windage tray on. the motor is in just waiting one more week for my paycheck to order heads. any input helps thanks
90 lx hatch |
1994 GT
what kind of money r u lookin to spend on heads?u can find some nice trick flows for about a 1000..or try to find trick flow R series around, but thats gonna be some cake for those ones
Cohagan Engineering, Inc. |
money isnt to big of an issue between 1000-1500 is ballpark and i have trick flow intake setup and 30 lb injectors and all that good stuff
90 lx hatch |
1994 GT
i would definitely look into some R series..it will be maybe a little more but brand new heads..or jus look for a lightly used pair..u could probably find those for that range..and no AFR will ever com close to what those heads r..even the best ported afr..those heads are it, doesnt get any better lol they are 225cc, cnc machined an all..check out all the classified on here in "engine"..check each thread..i kno there was a pair of R series for sale..cant remember if they were sold or not
1994 GT
and u plan on running 10-12 pounds from a turbo im guessing? ur gonna wanna step up the injector size for sure with that much boost...42's or 48's
#6 | |
1987 ford mustang gt
well see when shes done
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
the 185s would be good without the blower.....i would go probly a 205 if your gonna run the blower tho....its gonna be a beast no matter wat with a built 306 and boost
first of all thanx for the input this helps alot and i plan on going supercharged and run however much boost the block can handle its a stock block so im assuming the first thing to go will be the block. and somewhere in the 500 hp range if i make it there with 3:73's in the rear i can really go turbo or charged buyt still leaning for charger. and the t-5 lol but i looking into the t-56 soon after it goes. ill post pics of the engine bay when i can and try to take some of engine, but any more suggestions are more than welcome.
90 lx hatch |
with a 205 head with the right cam and intake with 12 psi will easily be over 500 rwhp
k i figured. i had a local cam shop grind me a pretty close replica of the comp blower cam. but i plan on running a .600 lift cam for the hell of it until i save up for the charger that way i can give the motor a thorough break in period and be loud and roudy for the time being
90 lx hatch |
85 GT/86 SVO/2010 GT500
one thing I see is what KB pistons do have flat's , domes, what?
they are flat's i was going to go dished to lower comp but figured that by getting a bigger head and running flats i could allow more airflow.
90 lx hatch |
he does NOT need 205 heads, please dont give information if you dont know what your talking about.
go with some AFR 185's, thats all you will need. also i do not recommend kb pistons for boosted aplications, especially 10-12 ppunds, they always break because of the high silicone content. invest in some probe pistons that will last you. and i doubt you will get the proper compression ratio with just a bigger head.
i will keep that in mind for next time around but i already have kb pistons in so ill give them a whirl but afr 185's should do what im looking for right? and the 10-12 thing is just at the track or whatever ill keep the boost down to around 5-8 lbs or so daily
90 lx hatch |
#16 | |
keep us updated on how it works.
Threads Similar to: rebuild almost done one question
| powerdyne super charger rebuild question | bob1june@yahoo.com | General Tech | 1 | February 24th, 2009 11:19 PM |
| Tranny question. Rebuild or get a different | gt_andy | 99-04 | 15 | June 6th, 2008 04:10 PM |
| the rebuild! | mustangfu | 5.0 Mustangs | 3 | May 17th, 2008 06:59 PM |
| My TA after the rebuild. | Blackbird1084 | Videos | 2 | April 12th, 2008 12:40 PM |
| rebuild question | 88MustangMarine11 | 5.0 Mustangs | 2 | December 28th, 2006 10:31 AM |
