twin turbo or single?
Old February 21st, 2009, 05:26 PM   #1
EscortSportage's Avatar
1989 Mustang GT 5.0
what are your comments for running a 5.0 on boost
twin or single? benefits, pro-cons, advantages and disadvantages of them etc...
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old February 21st, 2009, 05:27 PM   #2
yojoe600's Avatar
yojoe600 will become famous soon enough
where do u want your power?
Originally Posted by supermachone View Post
it was something like the tinman from the wizard of oz pinching off a tight fart...
Cat Club Co-Founder
Old February 21st, 2009, 05:37 PM   #3
1989 Mustang GT 5.0
im looking more into not as much top end power, but more into quick spools, 400 to 800hp range depends im like the way 650hp sounds...i just gotta figure out alot of things, id rather have 550hp with amazing throttle response and low lag, then 700hp with horrible response and lots of lag
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old February 21st, 2009, 05:40 PM   #4
yojoe600's Avatar
well def go twins then
Cat Club Co-Founder
Old February 21st, 2009, 05:40 PM   #5
blakehunter316's Avatar
1989 Mustang GT
14.01 @ 103..... :(
blakehunter316 is on a distinguished road
i think you need to set down and like think a little more before u give ur numbers 400-800? thats like streetable and sweet CAR. to a wicked only get out on super nice days when u feel like u have a huge pair of nuts car. just an idea
vortech s-trim off road h pipe super 40's steeda tri-ax c.a.i. 3.73s subframe cnntrs 255er
Old February 21st, 2009, 05:49 PM   #6
1989 Mustang GT 5.0
yea id rather have a badass street car but i want to road race and autocross, as well as drag and street race...so im thinking like 650hp give or take... quick spools power up to 7000rpm
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old February 21st, 2009, 06:08 PM   #7
Stealthy's Avatar
91 GT Stroker
Stealthy is on a distinguished road
Send a message via AIM to Stealthy
I want twins on low boost too. But everyone keeps saying that the stock block won't handle it. Good luck man.
Old February 21st, 2009, 06:09 PM   #8
The Razor's Edge
White Thunder's Avatar
stock block - single
aftermarket block - single
founder of the FTN Club
Old February 21st, 2009, 06:13 PM   #9
2008 Hammock Rodeo Champ
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
Squints has a spectacular aura aboutSquints has a spectacular aura about
Send a message via AIM to Squints
and a good aftermarket shortblock.
i have no mustang. so don't listen to anything i say.
Old February 21st, 2009, 06:22 PM   #10
1989 Mustang GT 5.0
this wont be on a stock block
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old February 21st, 2009, 07:14 PM   #11
89LX347's Avatar
89LX347 will become famous soon enough
call an engine builder. tell them everything you want to do blah blah. with all the things you just told us you want theres no way your gonna get solid answer from any of us.
you want 400-800HP then 650 sounds good. you want road race, street, and drag strip. you want top end power but quick spools.
i recommend theturboforums.com
sit and read my friend.
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old February 21st, 2009, 07:48 PM   #12
Sleeper_Stang_89's Avatar
1989 Mustang Gt
Run me and find out!!!
Sleeper_Stang_89 will become famous soon enough
are you absolutely set on a turbo? You can accomplish everything you want on motor... the most important thing to figure out is E.T. goals... even if its a street car...then go from there... you wouldnt want a dyno queen...
331 ways to WASTE an LS1...
I love pink
Originally Posted by sgrcltpunk View Post
dont fuck with bad pussy
Old February 22nd, 2009, 12:14 AM   #13
twin is a waste, you can make just as much power with a single setup and a stock block won't handle much past 450
Old February 22nd, 2009, 12:29 AM   #14
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
go to theturbofourms.com and read read read, there are people doing jy turbo kits for under 2k and making big numbers.
read read read.
Old February 22nd, 2009, 12:33 AM   #15
78mach1's Avatar
the A/R size is going to justify where your car will spool. im going to be turboing my black 88 soon and im going with a holset h1c.
my advice to you is to read as much as you can
Ford Mustang Turbo Size Guide - Muscle Mustangs & Fast Fords Magazine
that artical will help you with anything you need to know.
Old February 22nd, 2009, 03:17 PM   #16
1989 Mustang GT 5.0
what im trying to get at is...around the street ill run 5psi and just cruise with like 350hp or more just chillen then when i go to the strip boost it up to 15psi or more, im deffently set on turbo,(its the best power adder know to man) its more efficient and makes more power with less boost than supercharged, superchargers are parasites and better for quick and easy power, they are kool but im all about turbo hands down, and not to many people are running turbo foxes, (its different and more rare) sounds NASTY tooo! im going to be running megasquirt2 stand alone system (i think) and i can have pre-set tunes one for the street one for drag strip, one for road race, even for different weather and temps.It also depends on what kind of fuel im running, Lets say im cruising on the streets and then i hop on the high way and some evo or STi pulls up next to me...laptop is getting opened and my 5.0 is gonna go from a sick street car to a beast in seconds... ive been reading alot about turbo set ups and the physics of boost and turbo, i want to fully build my motor than once i got everything planned out turbo it... i
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old February 22nd, 2009, 05:11 PM   #17
78mach1's Avatar
with the way your talking you are going to need alot of funds, what set up do you have in mind?
what engine?.....what fuel system?......what turbo?.....you fabing up your own system?......suspension?.....stock t-5?
those are things that will be a big factor.
Old February 22nd, 2009, 05:14 PM   #18
JBIGBOOTSY's Avatar
1990 LX hatch
+1, there are fast spooling singles, twins...
Old February 22nd, 2009, 05:26 PM   #19
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
+1
O o
/¯/______________________
\_\
Old February 22nd, 2009, 05:43 PM   #20
1998 Cobra
13.24@105.66
Twin or single has nothing to do with how it spools and how much power it makes..
It all depends on how big the a/r / trim you are looking at.
But... one cool thing about d.i.y. twins is that two smaller, less efficient turbos can make just as much power as an expensive aftermarket single..
Perhaps twin hx35/h1c's
weeee foooord!
Threads Similar to: twin turbo or single?
Single vs. Twin Turbo BWAL General Tech 69 March 26th, 2012 02:21 AM
Twin vs single turbo forensicsteve 2005 - 2010 6 September 26th, 2008 10:32 PM
Single or twin turbo 97GSTANG 96-98 10 April 15th, 2008 07:31 PM
Twin or single turbo? energiesource 99-04 16 July 10th, 2007 12:08 PM
Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 Mellon Videos 10 December 30th, 2006 10:05 AM
