No start when hot... any ideas?
Old February 21st, 2009, 07:32 PM   #1
astras is on a distinguished road
OK, so the car will start up great when it is cold. Idles fine, revs good. If I let it sit running for a while, and shut it off it won't restart again.
Stock 302 w/ E303
Things I have tried/checked:
- Replaced the ECT
- Replaced the TFI module
- Have spark
- Timing is good
- Fuel pump makes the "hum" when you turn the ignition on
Only thing, is when I turn the motor over when it is hot and I press the release on the Schrader valve not much fuel comes out. I am going to get a pressure gauge tomorrow to check it out.
The other thing, when I put the engine back together I had gotten a little bit of gasket sealer on the ground strap. The first few times I fired the motor, it was very sluggish and the negative battery cable started to smoke.
I don't know what I might have fried (if anything) but it doesn't make sense that it fires right up like there is no problem if it's cold.
Any suggestions?
Old February 21st, 2009, 07:47 PM   #2
89LX347's Avatar
89LX347 will become famous soon enough
does it turn over when its hot? could be your starter. go back, if you havnt already, and make a good ground connection.
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old February 21st, 2009, 07:48 PM   #3
It turns over fine... doesn't even attempt to fire though. Starter is good.
Old February 21st, 2009, 09:36 PM   #4
Nice 5.0's Avatar
1993
12.9 @ 105
Nice 5.0 is on a distinguished road
If your getting spark the problem is on the fuel side. Check fuel pressure. If fuel pressure is good you need to see if you have injector pulse. Basically use a test light and probe the wires at the injector connection. Crank the motor over and the test light so pulse at a rapid rate. Make sure you check this when the car won't start. If you dont have a pulse then it's time to troubleshoot. That's where the fun begins. Luckily not much stuff to check on the fuel injection side. It could be a bad injector, sensor or computer. I've seen a bad TPS sensor cause the same problem. That should get you started.
Old February 21st, 2009, 09:58 PM   #5
TFI's dont like the heat.......................
PeteAndersonRacing.com
Old February 21st, 2009, 11:27 PM   #6
JohnC's Avatar
1997 Mustang GT
13.56@102.94
JohnC is on a distinguished road
Check the TPS, IAC, EGR, and coolant temp sensor?
1997 Mustang GT
Aluminum Block PI swap & 4R70W to TR3550 swapped.
Best 1/8: 2.04 60ft 8.74@81.85 &
Best 1/4: 2.045 60ft 13.56@102.94
all on stock 245-17's
My Garage
Old February 21st, 2009, 11:51 PM   #7
88stang's Avatar
1988 Mustang
88stang is on a distinguished road
Stock 302 w/ E303
- Replaced the ECT
- Have spark
- Timing is good
Any suggestions?
I'm curious? Is your car a standard shift and if so will it start if you try to push it off? I too experience the starting issue when the car has reached normal operating temp. I have had no luck solving this issue.
Old February 22nd, 2009, 12:00 AM   #8
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
OK. Here we go. I am 3 for 3.
Get a new computer or new tune. Your warm start side of the tune is bad. I am willing to bet ANYONE WHATEVER that your computer is at fault. Get a new computer and it WILL fix your problem....period.
Edit:
I have been through this...and THIS...and ONLY this is the reason why I am into modulars...
Old February 22nd, 2009, 08:36 PM   #9
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
Any luck?
Old February 22nd, 2009, 08:40 PM   #10
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
i've had this issue before on my old 5.0 and my timing was off. but you say yours is good so...
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old February 23rd, 2009, 09:21 AM   #11
Well, no luck yet. The funny thing is, you have ONE CHANCE to start the car. If you shut it off and try to restart it, it attempts to start. If you miss that chance, it won't start again until I do one of two things:
- Either wait til it's cold or
- Plug in my code scanner. All I have to do is plug it in. Don't even have to turn it on. The car will fire right up.
No 'effing clue. This is driving me nuts.
Old February 23rd, 2009, 09:29 AM   #12
zack065's Avatar
zack065 is on a distinguished road
Send a message via AIM to zack065
Edit:
i see this working
Old February 23rd, 2009, 09:34 AM   #13
1998 Cobra
13.24@105.66
high resistance, heat, burnt ecu trace possibly.
weeee foooord!
Old February 23rd, 2009, 10:43 AM   #14
haywood11's Avatar
1988 mustang lx
interior torn out!
haywood11 is on a distinguished road
Send a message via Yahoo to haywood11
if it shuts off when its hot and fires up when its cold i would check the ignition control module.........
88 5.0 with bbk shorties, bassani x-pipe w/o cats, custom 2.5in w/flowmasters. t-5 conversion, gt40p heads cobra upper and lower. stock SD.
Plans: full black interior, black paint and supercharger???
Old February 23rd, 2009, 10:46 AM   #15
91 LX
13.7@101
is it possible the starter is at fault? heat soaked?
Old February 23rd, 2009, 06:58 PM   #16
haywood11's Avatar
1988 mustang lx
interior torn out!
any takers on what i said?
Old February 23rd, 2009, 08:14 PM   #17
91 LX
13.7@101
actually yes that could be what it is too. i didnt read your post before.
Old February 23rd, 2009, 08:21 PM   #18
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
My 91 did this exact SAME thing! 1 shot...if you didn't touch the gas just right, it wouldn't start...
Swap out your ECU.
Old February 23rd, 2009, 08:21 PM   #19
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
It isn't that...
I love it when ppl don't listen.
Not directed at you...buuuuuuuttttt...
What I see here are a bunch of 'guesses' at what is wrong with his car. Try this, try that. I pulled my hair out for over 2 years trying to figure this problem out. Engine swaps, ignition swaps, TFI swaps, adding MSD components, stock Ford stuff, aftermarket stuff, wiring harness', EVERYTHING. IM telling you. Its the DAMN computer.
Tell ya what. If you swap it out and it DOESN'T fix the problem, I will send you the money for the computer myself VIA Paypal.
There is a 100% guarantee...
"edit"
Make sure you get the right Processor for your car.
Old February 24th, 2009, 07:18 AM   #20
haywood11's Avatar
1988 mustang lx
interior torn out!
WoW. +1 on that
p.s. (i still think im right) hehe
Threads Similar to: No start when hot... any ideas?
hot start issue jtyson8602 5.0 Mustangs 16 November 4th, 2008 07:22 PM
car won't start..any ideas jabrennan V6 Mustangs 43 January 29th, 2008 10:59 PM
89 5.0 No Start, No more ideas... Illuminator 5.0 Mustangs 5 June 15th, 2007 03:40 AM
Any Ideas (Won't Start) DragonFreak 96-98 13 September 24th, 2006 01:05 AM
please help!!!!! no start when hot....... gixxer1 5.0 Mustangs 12 August 22nd, 2006 08:01 AM
