current project... and i also need some advice on conerting from efi to carb
ok, so i have an 89 lx manual trans 302, i finally got a daily driver and im ready to do a low budget build.
i want to go carb because i dnt like fuel injection but im new to mustangs and im not sure how to convert it, from fuel setup to wiring set up, i more confused about the wiring aspect more then anything, im not sure if im doin 306 or 351 yet but either way it will be carb. so i need to knw like what parts im gonna need and how i do the conversion. i dnt have power windows or anything if tht helps... and i would appreciate as much help as possible and thx in advance. im gonna post some pix from when i started its not much yet because i dnt have alot of time. and i will list some of my questions underneath of this tgx in advans i appreciate as much help as possibke. What do i do with the stock computer? How do i set up ignition system inorder to run msd? what on the fuel side do i have to do to run carb as simple as i can? well basically i need alot of info pleas help thx |
87 stang + 97 ranger
both combined i can't break 15 secs.
I vote for 351 as the engine.
I can't help ya with your other stuff, I'm learning also. |
yea im thinkin 351 aswell but money is kinda tight right now so im tryin to weigh my options.. but thx
[IMG] [/IMG][IMG] [/IMG] the motor is ready to come out i just have to get my engine hoist back together and some bolts for my stand then the fun starts
You need:
special fuel injector -> carb fuel pressure regulator Fuel line (cut off factory fuel injection lines and clamp them on there.. run these to regulator Older distributor with correct gear for roller cam Carbed Intake Carb New vac lines for off carb Air cleaner Run wire for Ignition to distributor You can pull the whole engine efi harness and computer BUT you will have to wire up a fuel pump relay as the ecu controls it and oil pressure, watertemp and tach will not work.
weeee foooord!
check out my build thread. I did a 2.3 to 302 carb swap and it has lots of parts info you need. PM me if you need part numbers or anything!
Finally a fox owner!!
weeee foooord!
#8 | |
1997 Mustang GT
N/A
im doing this right now as a matter of fact this is how i did it. i went to autozone and got a ignition control module, distributor (with steel gear), cap for a 85 mustang with a carb i cna get all the part
#'s later they are on a reciept in the truck. holley blue fuel pump fuel lines odds and ends the only problem is i think i may stick with efi after all so if you want my carb/ intake let meknow. 1.fuel tank, you can pull out the stock pump and cut a piece of hose to go to the bottom of the tank as a pick up(this is the cheapest way and it works.) or install a sump on the tank. run a holley blue after the filter and then to the carb no regulator need the blue doesnt push that much fuel (unless you stretch the spring) 2.ignition:pretty simple if you just use the stock duraspark system from autozone, just need a lead thats Hot when the key is turning and a hot when the key is in the on position. Fuel delivery: pretty simple buy your carb and intake and bolt them right on And that’s about as far as I have gotten with install details I'm currently waiting on the motor to be finished before I decide to stay efi or finish the swap.
97 GT, a project I guess you could call it MILITARY CREW AT3 |
#10 | |
there is also a sump you can buy to go in place of your existing pump, but then you would have to buy a fuel pump that isnt gavity fed. holley is. here is a pic of mine before and after, maybe it will give you some ideas on how to do things. ![]()
![]() I believe in art when it is not seen. I believe in music when it is not audible. I believe in God when He is silent. Last edited by 89LX347; February 23rd, 2009 at 12:58 PM. |
1997 Mustang GT
N/A
[quote
[/quote]i like that msd box placement covers up the stock intake hole
thx for all the advice, how do i run the msd box though, ive jnever even hooked up an msd on anything so im kinda in the dark
it comes with instructions, or you can go on jegs and look them up. its not too hard though.
Threads Similar to: current project... and i also need some advice on conerting from efi to carb
| carb to efi | mustangsoldier | 5.0 Mustangs | 14 | November 1st, 2008 03:25 PM |
| EFI vs Carb | scxc15 | 5.0 Mustangs | 61 | February 20th, 2008 08:55 AM |
| CARB OR EFI | BLACKNIGHT5.0 | 94-95 | 10 | August 16th, 2007 03:39 PM |
| efi to carb please help | itsmyfiveoh | 5.0 Mustangs | 33 | June 20th, 2007 02:26 PM |
| EFI To Carb? | 88 stang gt | 5.0 Mustangs | 11 | October 26th, 2006 08:02 PM |
