T-5 Trans out of a sn 6cyl?
Is the 94 and up T-5 that comes in the v6 stangs the same as the older fox t-5 trans? I know the differences in the 4cly trans that came in fox 4 clys but confused slightly on the v6 t-5.
i know my 2000 v6 had a t5 in it. I THINK that it is the same transmission but I could be wrong
Has anyone used one on a 5.0 with success? They are easier to get from a junk yard than finding a t-5 for a v8 car.
i dont think you would have a problem taking a t5 out of a v6 mustang. go for it. im sure they are at least a bit stronger than the 4cyl t5's and people use those to drag race all the time
1989 Mustang LX
10.98@126.7 NA
94-95 6cyl T-5 is the same as a 94-95 8cyl T-5. Input shaft is longer than the pre 94 T-5. Could be made to work in a 5.0 Fox with 94-95 bellhousing or a change out of the input shaft. Shifter location would change if you used the longer input shaft setup.
Never fast enough.
Threads Similar to: T-5 Trans out of a sn 6cyl?
| 95 6cyl....convert to drag car | Sleeper_Stang_89 | 94-95 | 3 | July 27th, 2008 06:41 PM |
| 2005 Ford Mustang ( 6cyl. and 8cyl.) TSB's! | Casper98GT | 2005 - 2010 | 26 | February 17th, 2008 08:20 PM |
| 5-spd swap behind a 6cyl? | 6T8coupe | Classic Mustangs | 2 | May 30th, 2007 05:44 AM |
| t5 trans | johns86xr | 5.0 Mustangs | 1 | April 22nd, 2007 08:37 PM |
