Alternator?
Old February 23rd, 2009, 04:15 PM   #1
thekeysbucket's Avatar
1988 Mustang Notch 5.0L
not in yet
thekeysbucket is an unknown quantity at this point
Send a message via MSN to thekeysbucket
Alternator?
My battery died so I went ahead a bought a new one. I checked by starting the car then disengaging the battery cable and the car stopped running as fast as I took off the terminal. Is this a bad alternator? Also, I get shocked exiting the drivers side after driving, fun. Is the install easy with the new alternator and belt replacement? Should I put a battery kill switch in also to be safe? I'm changing it out today, so if you I can get help asap I would much appreciate it. Thanks guys.
5.0L LX Notchback Fast as Hell and willing to show it, My little DEVIANT!
Old February 23rd, 2009, 04:23 PM   #2
hotrodredneck's Avatar
hotrodredneck is on a distinguished road
the trick of pulling the terminal off doesnt work so well with FI cars. there is too much of an electrical draw. best bet is to get a volt meter or multi meter, and read the volts at the batt when the car is running. It should be around 14 vDC. as for getting shocked, sounds like you a good size short in there somewhere.
the install is not too hard for an alternator
Old February 23rd, 2009, 04:30 PM   #3
not in yet
And I forgot to mention that I had put under drive pullies on but im thinking that It's best to keep the stock pully on the alternator when I replace it.
Old February 23rd, 2009, 05:08 PM   #4
i am not a fan of UDP's the hp gain vs other issues are minimal. wait till your oil pump craps out, and your oil pan looks like this
not mine, was a buddies
Old February 23rd, 2009, 05:21 PM   #5
not in yet
Are you kidding me? So the 15hp gain isn't worth it now...thats just great. so...now what should do for the oil pump? I figured I can have a good hobby of fixing almost everything on my car but now I'm a little concerned about what these UDPs are doing, or what they are going to be doing to make my life miserable. Well...about the alternator, what do you think?
Old February 23rd, 2009, 06:22 PM   #6
1989 LX coupe 5.0L
89lx is on a distinguished road
no way ud pullies did that to the oil
Old February 23rd, 2009, 08:41 PM   #7
Newblet
87FloridaGT's Avatar
1987 GT
87FloridaGT is a jewel in the rough87FloridaGT is a jewel in the rough87FloridaGT is a jewel in the rough
x1000000000000000
Come on bro...UDP didnt cause that damage. Poor maintenace, spraying the hell out of the motor and other variables do that shit
Old February 24th, 2009, 02:02 AM   #8
UDP, caused the oil pump to sh@t.....
that and drunk prior owner driving it with 0 oil pressure. and that was only the #4 cyl rod bearing
Old February 24th, 2009, 03:02 AM   #9
1992 Lx
11.39@119.24
maybe in a mod motor where its externally balanced
Old February 24th, 2009, 03:06 AM   #10
1988 Mustang Notch
it's a bad bitch..i promise
CAMN89GT is infamous around these parts
UDP possibly could of caused the oil pump to take a shitter, however... that motor was ABUSED worse than a red headed step child, I'll bet 9.9 out of 10 that motor was sprayed with a 175 pill or higher.
'88 Notch ~ T-70 & Faceplated GForce!
Tuned by [B][I][U]Kurgan Motorsports[/U][/I][/B]
Old February 24th, 2009, 06:53 AM   #11
The Razor's Edge
White Thunder's Avatar
There is the more exspensive way. Eletric water pump fuel pump and fans. And the alternator change out should take less than 10 mins
founder of the FTN Club
Old February 24th, 2009, 08:58 AM   #12
baine21225's Avatar
easy as cake, and your not gaining 15 hp from the udp
"Whip out your dick you'll either get it sucked or get smacked..."
Old February 24th, 2009, 12:25 PM   #13
nah, just the guy who owned it was a drunk...that oils was in the pan for a few months after I had pulled the heads and all off and it was sitting in the garage for a couple months, waiting for another engine
what caused the damage was driving on it for a month.
as for the alternator....it shouldnt take long...but be sure to disconnect the battery first
Old February 24th, 2009, 12:43 PM   #14
not in yet
Alright yesterday after we talked I went to Kragen and had the alternator tested, the results were that it was over charging. I had installed the new battery into the car before the test was done just to make sure I was getting proper readings. This morning I jumped in all happy with my readings and spanking new juice....and it was dead again. So do you think it could be a bad ground now? I have a Chilton but the diagrams suck, way too small and confusing. What should I do, start from the battery and work my way out from it? I'm going to check and clean (possibly replace) and cables.
Old February 24th, 2009, 01:44 PM   #15
I would be willing to bet its near that door that is shocking ya
Old February 24th, 2009, 02:13 PM   #16
The Razor's Edge
Buy new cables there cheap
Old February 27th, 2009, 05:09 PM   #17
wow, white thunder, your avatar hurts my eyes...lol
If at first you don't succeed........
Skydiving is NOT for you
Old March 4th, 2009, 12:02 PM   #18
not in yet
Woowoowoohahahahaha
Alright done! I grabbed my tools and headed out to my parking lot and started ripping things out of my car. Now mind you, I live in an apartment complex. I got the best spot, you know the "Holy Grail" of parking spots so your wife can throw botttles of water from the balcony without coming down to drive you nuts. I started removing everything! I started with the radiator hoses to the power steering, the A/C, then to the alternator, fan, fan pully old POS water pump (which I think shellfish were living in), Belt and shroud (maybe not in this order) but I made the shit happen! I replaced the the water pump and the alternator. Put everything back into the car, except that one bastard bolt thats always gets left behind! But she works great and there isnt even a leak and...I don't get shocked anymore. So the mystery of a car that the battery dies while sitting but charges while driving is solved. Moral of the story is that if your 88 mustang is dying electrically when you have the neg cable off during the night but not while you drive, it's the the way the alternator works in those cars. Draws mysteriously when the car is shut down, change out the alternator ASAP! And theres a good chance you won't get shocked any more hahahahaha.
Old March 4th, 2009, 12:32 PM   #19
1993 mustang GT
50fanatic is on a distinguished road
I bought a 95 mustang newly remanufactured 130 amp 3g alternator for 80 bucks. Not ebay. Local. The pulley is the same size as the under drive pulley that came for my stock 2g alternator. I'll install that and the underdrive crank pulley, that comes with the set. I'm not touching the water pump pulley, cause I have a clutch fan, which will already slow down with the crank pulley. I just don't want it to slow down even more. The crank is 25 percent underdrive. I'm running a 180 degree thermostat and most of the time my temp gauge runs on A of NORMAL. Between A and L, locally.
Threads Similar to: Alternator?
Which alternator?? Drtbkercr5 The Clubhouse 0 April 10th, 2008 10:09 PM
alternator JStang14 99-04 3 April 1st, 2008 01:19 AM
alternator Murderjetz V6 Mustangs 6 July 26th, 2007 08:53 AM
New Alternator Thewolfman456 99-04 2 May 8th, 2007 08:31 PM
alternator 89mustanggt 5.0 Mustangs 5 May 19th, 2006 09:43 AM
