#21 |
I have 3.73 gears and work fine for me, I drive it everyday on the street, Plenty of top end. I say 3.73 is a good balanced gear
1995 Nissan 240sx. Coilovers, intake, full 3in exhaust, RUCAS, J30vlsd, 1 piece drive shaft, Q45 Front brakes, short throw, subframe collar bushings. |
#22 |
I would stick with the 3.73 so it will still be a decent driver. The 4.10 would be nasty though!
#23 |
manual trans FTW. what trans are you using? don't go any higher than 3.73. once my motor is built ill be switching back to 3.73 so i can run with the turbo boys on the highway
#24 |
FFR Cobra and 05' GT vert
I ended up going with a tko trans. I might just try out the 4.10's that are already in it. but I have 315/35-17 rear tires which is like a 25.7 inch tire so the gear is pretty steep with the 4.10.
Go big or go home! |
#25 |
1993 Mustang
we'll find out when i come home from iraq.
ill sell you my 4.56s lol
shut up before i punch you in the throat |
#26 |
1988 Mustang Notch
it's a bad bitch..i promise
Ah, the memories haha.... hell, when I thought 4.56's were fun, 4.88's was just humorous. It pulled so freaking hard.... Ahhhhhh the memories!
'88 Notch ~ T-70 & Faceplated GForce! Tuned by [B][I][U]Kurgan Motorsports[/U][/I][/B] |
#27 |
1994 GT
with the power u have, u dont need 4.10's..those are 2 short..3.73 or 3.55 for sure
Cohagan Engineering, Inc. |
#28 |
1990 mustang gt
eventually
i love my 3.55's
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
#29 |
TKO Box if you insist with a standard tranny. No factory ford transmission will last more than a few passes with that setup lol.
Keep the 4.10s and run a taller tire like a 28x10.50.. which will make it about a 3.90 gear. Still a bit too tall, but Im not sure what gear size is in the TKO box's first gear.
weeee foooord!
#30 | |
1993 Mustang
i hate being in 3/4 gear ALL THE TIME
#31 | |
Good luck with that manual transmission and 800+ horsepower on nitrous. Unless its a Liberty, Jericho or equivalent it is going to be laying in pieces all over the road if you ever spray it on a sticky tire.
#32 |
4.10 is the best.
Thanks. |
#33 |
85 GT/86 SVO/2010 GT500
#34 |
thing is a little pricey
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
#35 |
you gotta pay to play, specially when you wanna shift the gears with that many HP
#36 |
#37 | |
1988 Mustang Notch
Threads Similar to: What would you recommend?
| can anyone recommend? | jasons_98gt | 96-98 | 7 | November 12th, 2008 03:35 PM |
| What do you recommend? | TheLookerTheWatcher | The Clubhouse | 14 | June 23rd, 2008 01:44 PM |
| Can Anyone Recommend A Bumper | obdnanr | V6 Mustangs | 24 | December 19th, 2007 10:39 PM |
| What would you recommend? | brad03svt | 99-04 | 14 | October 4th, 2007 11:06 AM |
| Recommend one for me... | postie | V6 Mustangs | 6 | December 26th, 2006 09:51 PM |
