1990 mustang gt
eventually
speedo gear corrections
Manual Transmissions with 7 Tooth Drive Gear
* 1983-1989 T-5 OEM * Pre 1993 T-5 Aftermarket * 1996-1998 Cobra T-45 OEM * All Tremec Transmissions Manual Transmissions with 8 Tooth Drive Gear * 1990-1995 T-5 OEM * 1996-1998 T-45 OEM Except Cobra Automatic Transmissions with 7 Tooth Drive Gear * 1983-1989 Automatic Transmissions Automatic Transmissions with 8 Tooth Drive Gear * 1990-1998 Automatic Transmissions Manual 7-Tooth 2.73 Ratio / Maroon 16 Speedo Gear Manual 7-Tooth 3.08 Ratio / Yellow 18 Speedo Gear Manual 7-Tooth 3.27 Ratio / Pink 19 Speedo Gear Manual 7-Tooth 3.55 Ratio / Black 20 Speedo Gear Manual 7-Tooth 3.73 Ratio / Red 21 Speedo Gear Manual 7-Tooth 4.10 Ratio / White 23 Speedo Gear Manual 8-Tooth 2.73 Ratio / Yellow 18 Speedo Gear Manual 8-Tooth 3.08 Ratio / Black 20 Speedo Gear Manual 8-Tooth 3.27 Ratio / Red 21 Speedo Gear Manual 8-Tooth 3.55 Ratio / White 23 Speedo Gear Manual 8-Tooth 3.73 Ratio / White 23 Speedo Gear Manual 8-Tooth 4.10 Ratio / White 23 Speedo Gear Automatic 7-Tooth 2.73 Ratio / Blue 16 Speedo Gear Automatic 7-Tooth 3.08 Ratio / Gray 18 Speedo Gear Automatic 7-Tooth 3.27 Ratio / Tan 19 Speedo Gear Automatic 7-Tooth 3.73 Ratio / Purple 21 Speedo Gear Automatic 7-Tooth 4.10 Ratio / Black 23 Speedo Gear Automatic 8-Tooth 2.73 Ratio / Gray 18 Speedo Gear Automatic 8-Tooth 3.08 Ratio / Orange 20 Speedo Gear Automatic 8-Tooth 3.27 Ratio / Purple 21 Speedo Gear Automatic 8-Tooth 3.55 Ratio / Black 23 Speedo Gear Automatic 8-Tooth 3.73 Ratio / Black 23 Speedo Gear Automatic 8-Tooth 4.10 Ratio / Black 23 Speedo Gear
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
good stuff man
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
thank you. so my 91 lx 5 speed with 4.10's needs the white gear right? my speedo is way off
1990 mustang gt
eventually
correct.. i was hopin this would become a sticky
Honestly, I dont know anyone that ever changes their speedo gear when they do gear swaps lol It's a 9 dollar part and annoying as hell reading the wrong speedo
weeee foooord!
Without a tire size, that information isn't real accurate.
im doing my gears right now and i ordered the speedo gear at the same time......it wud drive me crazy not having a speed0
1990 mustang gt
eventually
i believe that is w/ stock wheels
1992 Lx
11.39@119.24
stupid speedo gear didnt do shit buy make my speedo Closer, i aint changin the one in the dash to get it perfect, waste of time
1988 GT
I'm going through this issue right now, went from auto to t-5 then to tko-500, with 3.73 gear... I e-mailed D&D performance in Mich. but odds are I'll jus wait until I order a new gauge bezzel just so I know everything is meant to work together... besides this sort of work sucks on the floor of your garage.
#11 | |
weeee foooord!
Threads Similar to: speedo gear corrections
| Speedo Gear.. | 94StAnG5.0 | 99-04 | 3 | June 12th, 2008 12:55 PM |
| Speedo Gear | G.T. Rags | 96-98 | 5 | September 17th, 2007 06:58 PM |
| Speedo Gear? | MustangMatt96GT | 96-98 | 1 | July 7th, 2007 05:04 PM |
| What Speedo Gear Do I Need? | Casper98GT | Modular Mustangs | 1 | May 24th, 2007 01:03 AM |
| 3.73 and speedo gear | untamed97stang | Modular Mustangs | 4 | April 26th, 2007 11:31 AM |
