Fuel Pressure
I have my fuel pressure set at 45psi is this good or bad it was at 38 but i think I was running lean so i bumped it up. I gotta 88gt with A9P computer, 306 with Gt 40 upper and lower, 24lb fuel injectors, cold air, 70mm mass air and throttle body, b303 cam, Edlebrock aluminum preformer heads, pro bullit dist., 6al msd, underdrive pully, hooker headers, bbk offroad h pipe, flowmaster exhaust and 373 posi.
That's probably a little high. 38 is probably closer but you should go dyno it when you get a chance so you can see where the air/fuel ratio is at.
yeap i just found a dyno for $70 and they will do it all. Thanks for the reply though
Threads Similar to: Fuel Pressure
| Fuel Pressure Regulator Leaking Fuel | Buttaz | V6 Mustangs | 4 | August 17th, 2007 11:41 AM |
| Fuel pressure | 8A_Honda | 5.0 Mustangs | 1 | August 16th, 2007 08:53 AM |
| Fuel Injectors/fuel pressure | 00silvergt | 99-04 | 4 | August 2nd, 2007 09:54 AM |
| No fuel pressure, Fuel gauge went above full and stayed. | woodz72 | 96-98 | 6 | July 10th, 2007 06:58 PM |
| fuel pump fuel pressure stuff | JBIGBOOTSY | 5.0 Mustangs | 2 | April 26th, 2007 03:31 PM |
