Cam choice
Old January 9th, 2007, 08:22 PM   #1
Nice 5.0's Avatar
1993
12.9 @ 105
Nice 5.0 is on a distinguished road
Cam choice
I have a 302 with windsor jr heads, e-303 cam, edelbrock performer intake, 70mm TB, 73mm C+L mass meter. I am building a new short block for it. Pretty much stock internals with forged pistons bored .040. I plan on having the heads shaved to get around 10:1 compression. My question is what cam would you guys use with this combo. The e-cam feels good but i know there are better options out there. I put this cam in the car about 8 yrs ago.
Old January 9th, 2007, 09:11 PM   #2
rodenberg's Avatar
rodenberg is on a distinguished road
A custom grind would be your best bet
bracket racing sucks
Old January 10th, 2007, 02:21 PM   #3
Nice 5.0's Avatar
1993
12.9 @ 105
What about an off the shelf cam. I'm on a budget.
Old January 10th, 2007, 05:32 PM   #4
rodenberg's Avatar
I run the z-303 but I think the x-303 might be good for you
Old January 12th, 2007, 05:20 PM   #5
Nice 5.0's Avatar
1993
12.9 @ 105
I keep hearing the letter cams are outdated. I'm trying to find a cam that will add the most power for my combination. I think the e-cam is a little small. I was looking the tfs stage 1 but it seems a little small also. The stage two seems too big. I'm trying to find a dual pattern. I don't mind a little loss in driveability this is my play car. I do drive it long distances though.
Old January 12th, 2007, 05:26 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Either one of the Trick Flow cams you mentioned will work good.
Threads Similar to: Cam choice
Take your choice TurboLX The Clubhouse 16 August 13th, 2007 09:53 PM
a choice Modern_Muscle 2005 - 2010 7 June 9th, 2007 05:16 PM
cam choice phat94 94-95 3 April 11th, 2007 07:48 AM
Cam Choice ninedee-coupe 5.0 Mustangs 27 October 30th, 2006 09:29 PM
cam choice... 2ToneFox 5.0 Mustangs 4 August 13th, 2006 01:46 PM
