What causes engine vibration?
LinkBack (1) Thread Tools
Old February 26th, 2009, 11:06 AM   1 links from elsewhere to this Post. Click to view. #1
Haven't run it
fatoeknee is on a distinguished road
Guys, at low RPM my engine vibrates moderately and it seems like it stops after I get above 2100 RPM or so ...I checked my plugs and they all looked ok. Looked at the motor mounts and they checked out fine too - on top of that I have no CEL so I'm pretty much stumped. I'm workin on a 5.0 fuel injected 1968 coupe that I just got runnin...
Any input or ideas would be great
Thanks a bunch
Tony
Old February 26th, 2009, 01:01 PM   #2
95StangMX's Avatar
95 Mustang GT
is the motor stock? Was it running ok and just started doing this?
Old February 26th, 2009, 01:05 PM   #3
1992 Lx
11.39@119.24
Thanks a bunch
Tony
my cars EXACTLY the same, i think mine is the harmonic balancer cuz i can see some of the rubber like coming out of it
Old February 26th, 2009, 01:11 PM   #4
95StangMX's Avatar
95 Mustang GT
+1 or if its a rebuilt motor with a new rotating assembly that was balanced poorly
Old February 26th, 2009, 01:39 PM   #5
Haven't run it
I actually thought it could be a balance issue ...motor has been sitting for some time (probably 4 plus years) ...I'm trying so hard to remember but I think the balancer I bought for it was a new 50 oz replacement along with the flex plate for the c4 being a 50 oz replacement as well - never got them balanced to the motor though. Can a balancer go bad just sitting? LOL - i had to scrape a ton of rust off it just so I could see the timing marks to set timing.
Old February 26th, 2009, 01:56 PM   #6
91cobra5.0's Avatar
98 Cobra
i dont think that the balancer could go back but think of all those chmicals building or eating at the block or crank or werever, if it sat for 4 plus years u may have to rebuild it, did u do compression checks to get a idea of the shape the cylenders are in?
Old February 26th, 2009, 03:11 PM   #7
89LX347's Avatar
89LX347 will become famous soon enough
a stuck lifter
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old March 2nd, 2009, 03:07 PM   #8
Haven't run it
Did a compression check ...all cylinders are within 130-150 suprisingly - any other ideas guys?
Old March 3rd, 2009, 11:31 PM   #9
BUGMAN's Avatar
BUGMAN is on a distinguished road
If the motor is 28oz balance then it will do the same thing even with a 50oz balancer and flex plate/fly wheel. What year is the motor and if it was rebuilt what was the build balanced at? I have 28, 50 and 0 balanced 302 EFI's and carb'd and if they aren't matched you will get the same thing.
You haven't failed until you stop trying.
Old March 4th, 2009, 12:04 AM   #10
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
wat about ur u-joints? easy check
Cohagan Engineering, Inc.
Old March 4th, 2009, 12:19 AM   #11
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
ya its time to change yours.. get a sealed one
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old March 4th, 2009, 01:31 AM   #12
Haven't run it
Engine is a 1991 ...Today I noticed a little condensation coming out of my tailpipes on and off and now I'm wondering if that has anything to do with it - the little puffs of smoke that come out are just slightly white but don't smell like antifreeze. Makes me angry I should have bought everything new but I tried to cut corners and bought all used parts
Old March 4th, 2009, 04:27 AM   #13
chickenbot's Avatar
1990 mustang gt
eventually
are you letting it warm up? it could just be condensation from when you parked it.. drive it around for a lil while and does it still do it?
1990 gt 5.0
3.55 gears
Old March 4th, 2009, 09:57 AM   #14
Haven't run it
Still does it after it's warm
Old March 4th, 2009, 10:23 AM   #15
chickenbot's Avatar
1990 mustang gt
eventually
do you smell maple syrup?
1990 gt 5.0
3.55 gears
Old March 4th, 2009, 10:47 AM   #16
2008 Hammock Rodeo Champ
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
Squints has a spectacular aura aboutSquints has a spectacular aura about
Send a message via AIM to Squints
1:31 AM
10:23 AM
i have no mustang. so don't listen to anything i say.
Old March 4th, 2009, 10:59 AM   #17
chickenbot's Avatar
1990 mustang gt
eventually
shhh.. maybe he doesnt know that hot antifreeze smells like maple syrup lol
1990 gt 5.0
3.55 gears
Old March 4th, 2009, 11:03 AM   #18
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
+1
check out the rubber in your balancer
Old March 4th, 2009, 12:31 PM   #19
chriswao's Avatar
1989 mustang gt
8th 5.70
chriswao is on a distinguished road
vaccume leak?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/112342-what-causes-engine-vibration.html
i have a manual 2002 ford mustang 6cyl 3.8 liter that has a - JustAnswer This thread Refback July 3rd, 2011 04:20 AM
Threads Similar to: What causes engine vibration?
Vibration Rhythm Stick V6 Mustangs 27 August 21st, 2012 12:05 PM
Engine vibration at certain rpm wolverine8490 96-98 12 July 27th, 2012 07:54 PM
Vibration after 65 lwhitetrash88l V6 Mustangs 24 February 27th, 2008 12:35 AM
vibration hmotes 5.0 Mustangs 8 January 5th, 2007 02:30 PM
vibration cali 5.0 5.0 Mustangs 7 June 8th, 2006 07:44 PM
