Any benefits to an Intake Mani spacer??
Old February 26th, 2009, 12:20 PM   #1
1992 Lx
11.39@119.24
I have one sean gave me sittin in the shed we're gona throw on today cuz we got some free bolts long enough, so far all ive read is it keeps down heat transfer between the upper and lower and helps clear tall valve covers, im assuming this is about it right? i think its a half inch spacer
Old February 26th, 2009, 12:23 PM   #2
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
yeah thats all i have ever heard in ways that they help
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old February 26th, 2009, 12:24 PM   #3
1992 Lx
11.39@119.24
funk it we'll throw it on when my friends off work and ill find out for myself
Old February 26th, 2009, 12:28 PM   #4
1990 Mustang GT
which intake.....gt40 right?
1990 GT
2004 Impala SS
2001 Tacoma
Old February 26th, 2009, 12:32 PM   #5
1992 Lx
11.39@119.24
yessir, explorer intake with no 5.0 badge to reduce weight
Old February 26th, 2009, 12:49 PM   #6
1990 Mustang GT
now thats the kinda thing that will always keep you that one step ahead of the competition
1990 GT
2004 Impala SS
2001 Tacoma
Old February 26th, 2009, 02:15 PM   #7
1992 Lx
11.39@119.24
anyone else got any opinions?
Old February 26th, 2009, 02:52 PM   #8
91cobra5.0's Avatar
94 GT
u think it may hurt your low end power? raising the intake will make the time the air has to reach the chambers longer so.... maybe lose a few hp and bottom end and gain a few at top?
94 GT - Deep Forest Green
Off road X, flowmaster single chambers, typhoon intake, hurst short throw, CAI, eibach sportlines, 315s, foxbody short block
Old February 26th, 2009, 02:56 PM   #9
1992 Lx
11.39@119.24
hmmmmmmmmm maybe? but shorter runners give better high end so maybe itll do the opposite? idfk niggha
Old February 26th, 2009, 02:59 PM   #10
91cobra5.0's Avatar
94 GT
im sure it wouldnt be a huge difference, hell maybe u will get like +1 to your mpg with all that cold air lol, is your intake manifold gona clear the hood?
Old February 26th, 2009, 03:02 PM   #11
93HatchsBFF's Avatar
1989 LX
12.60 at 109mph
93HatchsBFF will become famous soon enough93HatchsBFF will become famous soon enough
intake spacer bigger throttle body!!! :-O
1989 LX mustang, 5speed, 108,xxx miles, Mac Longtubes, BBK midpipe, Paxton Novi 1000 6psi, Crappy FMU with 19lb injectors, 373 gears
soon to come
30lb injectors, Blow through MAF, intercooler and tune
Old February 26th, 2009, 03:04 PM   #12
1992 Lx
11.39@119.24
get off the internet at work and change some fucking oil!!!!!!!!!!!!!!! then get ur ass here and help me do the spacer so we can go lift
Old February 26th, 2009, 03:04 PM   #13
1992 Lx
11.39@119.24
uhhhhhhh yes? lolol i dont think its even close
Old February 26th, 2009, 03:13 PM   #14
mxnate116's Avatar
88 mustang GT
mxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the rough
when i put the new 65mm throttle body on from summit the vent tube put a dent in my hood.
i would check the clearance before you slam the hood down.
Old February 26th, 2009, 03:23 PM   #15
1992 Lx
11.39@119.24
rotfl foshizzle ill make sure but i dont think it will
Old February 26th, 2009, 04:49 PM   #16
2008 Hammock Rodeo Champ
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
Squints has a spectacular aura aboutSquints has a spectacular aura about
Send a message via AIM to Squints
i was about to say this. i've got a one incher on mine and without a cowl hood, it would definitely be all up in da hood... fo shizz.
at least looking at it from the side it looks like it would. it sticks up quite a bit. well, it used to. now it's on my garage floor with about elevnteen other things that i had to removify.
i have no mustang. so don't listen to anything i say.
Old February 26th, 2009, 05:36 PM   #17
1992 Lx
11.39@119.24
rotfl spacer install FAIL i barely had one of the bolts tight that goes in the middle under the lil 5.0 badge and it stripped the fuck outa the threads on my lower, so we took out the spacer and tightened down all the bolts but that middle one doesnt get tight LOLOLOL sooooo needless to say im gona be getin a new intake mani as my next mod, fuck this explorer intake first the casting where the fuel rail tightens down cracks then shit strips
Old February 26th, 2009, 06:15 PM   #18
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
sorry about your busted breather piece. want a cobra upper/lower and 1" spacer?
only $799,999.95(canadian)
Old February 26th, 2009, 06:33 PM   #19
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
do you have an egr spacer on your intake set up? if so its worthless.. if not then go for it
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Threads Similar to: Any benefits to an Intake Mani spacer??
new intake mani?! 03TropicGt 99-04 18 July 28th, 2008 02:12 PM
Stock intake mani? 93HatchsBFF 99-04 13 July 18th, 2008 09:59 PM
GT 40 intake mani off explorer 93hatch 5.0 Mustangs 12 February 21st, 2008 07:31 PM
heads cams intake mani nHuman 96-98 3 February 19th, 2008 12:32 AM
PI intake mani, and injector size josh95mx 96-98 3 December 27th, 2006 01:05 AM
