Oil Pan Bolt Stripped
Alright was going to change my oil and ended up the thread of the bolt is stripped nothing is leaking and i can turn it with my hand it just wont tighten or loosen anymore. i was wondering if anyone had any suggestions on what to do.. am i going to have to get a whole new pan? is it a hard replacement?
2008 Hammock Rodeo Champ
helicoil, or tap to a bigger size and get a new bolt
i have no mustang. so don't listen to anything i say. |
they make these little things that fix it at the auto parts. call them up and tell them your situation. or you could tap it out, but that means pull your pan so the shavings dont get in between your bearings.
i like his idea better.
This may sound over the top, but why not get a new oil pan? This way you will have new gaskets also. Stock pans arent that much from the local parts dealer. I say "Dealer" because those damn parts are like drugs to us 5.0 heads! Just can't get enough, hahahaha.
![]() 5.0L LX Notchback Fast as Hell and willing to show it, My little DEVIANT! |
alright thanks guys.. always know i can get some good advice on here.. so you think a local parts store is the best bet for a new one... figured since i would have to pull it to tap it mine as well get a new one if there cheap... are they hard to replace or do you just drop that sway bar and unbolt?
never had good luck with stripped pan bolts.. always needed a new pan.
I have a few spare oil pans laying around, if you need one let me know
weeee foooord!
1989 LX coupe 5.0L
go to an auto parts store and get an over sized self tapping drain pulg and washer and it will be as good as new , it'll be like 5 bucks
1990 Mustang GT
13.64 @ 101 MPH
why get a new pan if you can put in a heli coil or use a self tapping bolt? you have to pull the engine out a considerable amount to change the pan out. if your gonna replace the pan just get an aftermarket with a windage tray an go ahead an get a better oil pump too. increase performance and fix the prob all at once. oil splashin around on the crank and all that uses 15% of the engines power from what i heard.
![]() 90 Ford Mustang 5.0 T5- BROKE 1.9 60' on street tires13.64 @ 101 MPH 89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8 Last edited by GoodOleBoyzRacin; February 26th, 2009 at 09:35 PM. |
there is still metal shavings in the pan once you helicoil... not a good idea.
weeee foooord!
Put heavy grease on the tap, no shavings will get in the pan they will stick to the grease. I've done a number of vortech oil drains this way and never had to remove the pan. Also a magnetic pan bolt is useful.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#12 | |
do the grease thing, then run like a quart of fresh oil in the motor with the plug out
weeee foooord!
#13 | |
85 GT/86 SVO/2010 GT500
Then get a gallon of kerosene dump through the motor as clean up |
Threads Similar to: Oil Pan Bolt Stripped
| stripped bolt | Monster90 | 99-04 | 18 | January 18th, 2009 07:05 PM |
| Anybody need an oil pan? | dude496 | The Clubhouse | 23 | October 28th, 2008 11:17 PM |
| Oil Pan | 91 gt 5.0 | 5.0 Mustangs | 3 | March 24th, 2008 11:06 PM |
| kickout 7qt oil pan w/low oil sensor hole | Iownastang | 5.0 Mustangs | 2 | July 19th, 2007 01:17 AM |
| Stripped a bolt... stupid mistake... need help... ideas? | JU$ | 5.0 Mustangs | 6 | June 15th, 2006 08:15 PM |
