Could it be the EGR??
Old February 26th, 2009, 11:47 PM   #1
Traidmarx's Avatar
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
Traidmarx will become famous soon enoughTraidmarx will become famous soon enough
i've had an issue with my car for a while running rough. Sputtering bad at crusing speeds. But for the most part the car runs strong at wide open throttle, sometimes it'll seem like its flooded out then take off once it gets past 3000 rpms. So far i've put all the following...255 lph walbro pump,new fuel filter,accell distributor,new plugs,8.5mm MSD wires,msd blaster coil,new igntion module, new tfi module and new harmonic balancer. the car only seems to really miss or sputter at crusing speeds but when i push in the clutch and rev it up about 95% of the time it'll rev up fast with no problems, occasionally it'll rev slow. I'm not sure what else could be causing it.
1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon.
Old February 27th, 2009, 12:41 AM   #2
1998 Cobra
13.24@105.66
fuel pressure? With that big of a pump might be putting the hurt on your stock fuel regulator
weeee foooord!
Old February 27th, 2009, 12:43 AM   #3
1992 Lx
11.39@119.24
stock regulator FTW mines workin fine with the walbro
Old February 27th, 2009, 12:49 AM   #4
1998 Cobra
13.24@105.66
hm....... Egr problem sounds possible though.. clean the carbon out of it
weeee foooord!
Old February 27th, 2009, 03:21 AM   #5
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
vacuum leak? Mine did that and I looked under the hood and one tube fell off the tree.
Old February 27th, 2009, 04:31 AM   #6
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
codes?
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old February 27th, 2009, 04:39 AM   #7
meh
Notcho's Avatar
Notcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to behold
Send a message via AIM to Notcho
Probably not a weak fuel pump. If the pump was not putting out enough, it would starve for fuel at higher RPM...
You said you replaced the plugs.. what did the old ones look like? All the same? Was one or two dirtier than the others? Check the plugs in it now. I had a similar problem with my old truck.. just cruising it would backfire and pop, but when I held it to the floor it would run perfect. Turns out one of the plugs was fouled with oil-ash deposits. I cleaned that plug and it ran fine afterwards.
'87 2.3 Notch with +4 cylinder mod
Ass, Cash, or Grass.. nobody rides for free
Black Stang Crew Member #11
Old February 27th, 2009, 06:54 AM   #8
King of Clubhouse
Till's Avatar
I know all about zombies!
I killed a zombie in .3 seconds
Till is a splendid one to beholdTill is a splendid one to beholdTill is a splendid one to beholdTill is a splendid one to beholdTill is a splendid one to beholdTill is a splendid one to beholdTill is a splendid one to behold
Send a message via AIM to Till
Im shooting with EGR or vacuum leak, mine done the same thing but I sold her before I figured it out hahahaha
Originally Posted by quickndslick2 View Post
^^go burn in a fire
Dumbass Club Founder
MM + Cleavage member #23
Old February 27th, 2009, 09:47 AM   #9
fateisajester's Avatar
1989 Ford Mustang
3 mins
fateisajester is on a distinguished road
Send a message via AIM to fateisajester
could be a bad coil. not putting out enough juice at lower rpms. Or wires. Or plugs.
Definatly not a fuel problem
Old February 27th, 2009, 12:22 PM   #10
Traidmarx's Avatar
1995 Mustang GT
Originally Posted by chickenbot View Post
codes?
it never throws any codes, the check engine light will come on and cut off, but i've taken it to 3 shops to have it checked and all of them say it shows no codes stored.
i went through and fixed all the vacuum leaks all around the same time, found a huge one whoever had the car before me apparently took the throttle body off and put no gasket or anything back on it. but i'll check the hoses again to make sure.
well as far as all that, i've got brand new plugs, brand new 8.5 mm msd wires, and brand new msd blaster coil.
Threads Similar to: Could it be the EGR??
EGR VS EGR delete? riggsracin 94-95 5 December 14th, 2008 11:56 AM
EGR all5.0motor 94-95 9 October 23rd, 2008 01:39 PM
egr ???? armymike63b 99-04 5 September 13th, 2008 02:50 AM
egr cali 5.0 5.0 Mustangs 2 April 29th, 2007 11:11 AM
EGR terribleonexx88 5.0 Mustangs 16 November 17th, 2006 09:30 PM
