open loop and closed loop
Old February 27th, 2009, 01:41 PM   #1
demonicus's Avatar
1988 mustang LX coupe
demonicus is on a distinguished road
Ok so I've got this motor... she looks really pretty.
visualize:
302 bored .020
GT40 intake
trickflow TW heads
23lb injectors
deep sump oil pan
BBK heads
now the car will fire up... run like a dream for 5 mins while in open loop.
As soon as the car warms up she goes into closed loop and starts blowin smoke, misfiring, hesitating etc...
now I have no idea what open loop and closed loop are but I'm wondering if ringwash is the issue then can I just throw a carb setup on it and be done with the whole ordeal?
89GTcoupe- 304ci, tfs1cam, tftw heads, 2.5"flowies, GT40intake, TF23lb inj, t5 w CFDF, SN5bolt, 3.73gears, GTkit, Y2K R wing, 17" Tribars
88coupe- lookin for a new powerplant
Old February 27th, 2009, 02:20 PM   #2
91 LX
13.7@101
im guessing a carb setup would help out big time
Old February 27th, 2009, 02:36 PM   #3
Trick Tuners's Avatar
KB'd GT
Maybe the o2s are bad? Any header leaks?
Open and Closed loop Fueling and Fuel Trims - Trick Tuners Forums
Old February 27th, 2009, 04:26 PM   #4
89LX347's Avatar
89LX347 will become famous soon enough
open loop and close looped have to do with your 02 sensors. putting a carb on anything doesnt solve problems like clorox. you need to see what the problem is right now. go get a tune, turn your fuel pressure down, do something. sounds like it just gets flooded or something. ive never heard of 23lb injectors and do you have one trick flow head and one BBK head?
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old February 27th, 2009, 05:26 PM   #5
1998 Cobra
13.24@105.66
coolant temp sensor, o2 sensors
weeee foooord!
Old February 28th, 2009, 11:31 AM   #6
demonicus's Avatar
injectors say 23lb on the side of them... 3 big holes in them (disc type) and the only ones I've ever seen advertised that look like them are from trickflow.
I have trickflow heads with BBK headers.
I'm wondering if a compression test will tell me anything.
Old February 28th, 2009, 11:46 AM   #7
JBIGBOOTSY's Avatar
1990 LX hatch
do you havematching maf for the inj.?
Old February 28th, 2009, 11:57 AM   #8
fateisajester's Avatar
1989 Ford Mustang
3 mins
fateisajester is on a distinguished road
Send a message via AIM to fateisajester
+1
i couldnt be happier since my carb swap
Threads Similar to: open loop and closed loop
shaft loop gooberhead320 The Clubhouse 24 June 15th, 2008 03:22 AM
Driveshaft safety loop shurb125 5.0 Mustangs 17 March 21st, 2008 08:48 PM
Drive Shaft Loop JONJON 5.0 Mustangs 11 December 8th, 2007 07:02 PM
Drive shaft loop GreenFaleen V6 Mustangs 2 May 4th, 2007 06:48 PM
Driveshaft Loop Plans Twist 2 Go General Tech 4 August 24th, 2005 08:46 AM
