1989 LX coupe 5.0L
What can cause this???
ill try and make this short and to the point, i keep fouling #7 plug. the oil pump shaft broke early in the year and a drove it for a few km's beofre i shut it down. i have 120 psi compression on the cly, spark and fuel. i tore the intake off and the heads off because i am upgrading. when i i tore the head off the gasket has fine and the top of the piston is covered with wet gunk (not coolant from taking the head off) and the valves to.
heres some pictures http://memimage.cardomain.com/ride_i...0046_large.jpg http://memimage.cardomain.com/ride_i...0045_large.jpg
Oil is fouling the plug.....time to rebuild
PeteAndersonRacing.com |
Could be a bad piston ring thats getting oil blow by, or the valve guide could be going. If you are up for it, take the piston out and check the rings.
1990 mustang gt
eventually
ya you should be getting 150 psi at each cyl
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
1989 LX coupe 5.0L
a rebuild was on the plan just because of the oil pump shaft, i ll have to take the piston out and ill let ya know
150-160 is normal.might wanna do a leakdown but most likely its your rings.
1989 LX coupe 5.0L
engine is already pulled, let the fun start
